Kris79 Posted March 20, 2014 Share Posted March 20, 2014 Hello everyone. We decided to buy another car rather than fixing our super fun super beat up bush car. It's a 1994 red Loyale 4wd wagon. Runs really well and doesn't seem to have the annoying valve noise either. However driving it home last night it makes a whining noise in all the gears and I'm concerned about this. Appreciate any thoughts/advice on what it might be. Also the front axles have been replaced within the last year or so. Link to comment Share on other sites More sharing options...
bratman18 Posted March 20, 2014 Share Posted March 20, 2014 Check gear oil? Link to comment Share on other sites More sharing options...
Kris79 Posted March 20, 2014 Author Share Posted March 20, 2014 It's low, will top up today and see if it helps. Our other car was low too but never had the noise. -Thanks Link to comment Share on other sites More sharing options...
wagonist Posted March 20, 2014 Share Posted March 20, 2014 Put the car in neutral whilst still moving & see if the noise is still there. Link to comment Share on other sites More sharing options...
skishop69 Posted March 21, 2014 Share Posted March 21, 2014 Either the input shaft bearings or the ring and pinion. Usually once the start to whine, the will continue. The donor 5spd for my Brat did. Luckily, I had a 2wd parts tranny so I swapped the ring and pinion. All quiet now. Link to comment Share on other sites More sharing options...
Kris79 Posted March 21, 2014 Author Share Posted March 21, 2014 I filled it with the proper fluid and it didn't seem to make a difference. The car only makes the whining sound when accelerating, if I back off the gas it disappears. Does this sound like something that needs immediate attention or can it be driven as if. I still have the same car for parts and before I ruined the clutch it didn't make any noise while driving as this one is. Link to comment Share on other sites More sharing options...
skishop69 Posted March 21, 2014 Share Posted March 21, 2014 As you described it, sounds like ring and pinion whine. Could go on forever or could eat itself. If you have the other tranny, swap it out. Link to comment Share on other sites More sharing options...
Kris79 Posted March 22, 2014 Author Share Posted March 22, 2014 Thanks guys, gave me some options. I have no idea how to swap a transmission though so if it die's it's dead lol Link to comment Share on other sites More sharing options...
Ibreakstuff Posted March 22, 2014 Share Posted March 22, 2014 Does the whine happen ever at all while coasting or clutch in? Or is it speed specific? Same noise when turning? Is it a whirl or a rumble? Link to comment Share on other sites More sharing options...
Kris79 Posted March 22, 2014 Author Share Posted March 22, 2014 It makes a bit of noise in neutral and the noise goes away when you press in the clutch. I would say its a whir more than a rumble. It doesn't make a difference turning right or left. Only when giving the car gas and its the same in all 5 speeds. Makes no difference in 4wd or 2wd. We really like this car and hoping it doesn't need a transmission. Link to comment Share on other sites More sharing options...
Ibreakstuff Posted March 22, 2014 Share Posted March 22, 2014 (edited) Could just be the throw out bearing (whirls but only when the clutch is not pressed in), how old is your clutch? I ask because if is just a TO bearing, you might be able to delay replacing it until your next clutch job. It may get louder.. it may not. Worst case it could lock up and prevent the shift fork from being able to disengage the clutch. But it shouldn't really cause more damage.So my advice would be, drive it until it gets worse! Good luck, hopefully she doesn't leave you stranded anywhere. ps- I am not a certified mechanic, I just had a weird feeling it could just be a noisy TO bearing.. Edited March 22, 2014 by Ibreakstuff 1 Link to comment Share on other sites More sharing options...
