oil leak front centre of oil pan
ea82 turbo efi motor now runs great  BUT It appears to be leaking oil from the front centre of the oil pan ,Have tried 3 times ,used bluemax loctite (1), the rightstuff permatex (2) and last time two gaskets with j3 earo gasket goo . Only ever leaks from the one spot every time which is where the block  split is joined . Any suggestions  sounds like a replacement motor is required ?
           Tony J
