issjoe Posted March 23, 2014 Share Posted March 23, 2014 Can I do a direct swap of a 2000 ej251sohc into a 1999 Subaru Outback Limited with ej25d dohc? Link to comment Share on other sites More sharing options...
johnceggleston Posted March 23, 2014 Share Posted March 23, 2014 no, not an easy direct swap. your best solution using those two engines is to use the 00 block and install the 99 heads, intake, etc. and then install it in the 99 outback. or find an ej25D 96 - 99 (NOT the 99 forester) or an ej22 95 - 98 and use that . Link to comment Share on other sites More sharing options...
issjoe Posted March 23, 2014 Author Share Posted March 23, 2014 Thank you for the answer. I searched the old posts, but couldn't figure it out. Link to comment Share on other sites More sharing options...
