Mugs Posted March 26, 2014 Share Posted March 26, 2014 (edited) OK so its been a few years since I have built a frankin motor. And in reality I am not building one this time, I am building more like a 2.5 hybrid. But my question is this: I forget what to order in the way of parts, because I know you have to mix and match a bit. Do I order belt kit for a 2000 2.2 since that is the heads I am using. And head gaskets for the 2003 2.5 block, since that is the block I am using. Or do I order everything for a 2000 2.5 engine since that is pretty much an 2.2 just bigger pistons. Or do I order everything for a 2000 2.2 Your thoughts... And thanks. P.S. the build is this, which may help answer some of the questions. 2003 EJ25 block 2000 EJ22 Heads (they have the same cfm flow and design as EJ25 heads, just single port) 2003 EJ25 cams with stage II grind. Edited March 26, 2014 by Mugs Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 26, 2014 Share Posted March 26, 2014 Have to order head gaskets for the block to match the bore size. So you'll want 2.5 head gaskets. Timing belt I'm not sure on the phase2 engines. I do know the blocks are all the same width, (can stick a phase2 block between phase1 heads with no other parts needed) so I would match the TB kit to the heads and call it good. Link to comment Share on other sites More sharing options...
MilesFox Posted March 26, 2014 Share Posted March 26, 2014 general rule: head gaskets match the block, timing belt match the heads. as far as i know, the sohc phase 2 2.2 and 2.5 use the same belt and pulleys. but phase 1 and phase 2 use different belt and sprockets from eachother. Link to comment Share on other sites More sharing options...
Mugs Posted March 27, 2014 Author Share Posted March 27, 2014 Thanks, I was thinking in this direction, but I was just wanting to get a second opinion, or 3 :-) Link to comment Share on other sites More sharing options...
