Homemade Loyale bumpers
Take your bumper off and look at the framerails.measure how big of metal you can use for your mounts.Stick something roughly the same size as that into your "frame rails" to check the depth you can slide the mounts into the framerails.Then figure out where you want your bumper to sit.measure that,measure about how wide you want the bumper then go draw up some plans to make the bumper with things you have to make it with.IE don't design in fancy curves if you don't have a tube bender..
no one really has "plans" for bumpers, its more of a measure a few things and buy a bunch of steel and fab something up on the car.All the bumpers I have built have started with a general idea of what I want them to look like.Then I stick the steel into the frame rails and weld the bumper to them.Then remove everything for final welding.
My personal preference is to stick the bumper mounts as far into the frame rail as they can go and use as many bolts to hold it as possible.
Edited by Uberoo
  • 2 weeks later...
