the.fedora Posted March 29, 2014 Share Posted March 29, 2014 A few weeks ago I noticed a coolant leak, and tracked it down to an intake manifold gasket -- no problem, just pull the manifold and replace the gasket (or so I thought). I wound up busting a stuck bolt, and had to drill it out, unfortunately I managed to drill through a head mounting stud in the process -- I didn't notice this, however, until I tried to turn the engine over and wound up filling my cylinders with coolant. Now, I need to replace a stud, and probably the head as well -- I put a small divot in the bottom of the thru-hole while drilling through the stud, I assume that it is this combination of busted stud, plus divot, that led to coolant in the cylinder. Does anyone have any advice, or a head (left side, ea81) they can sell me? I'm in Albuquerque, NM Link to comment Share on other sites More sharing options...
Crazyeights Posted March 30, 2014 Share Posted March 30, 2014 I have a good used pair if you get stuck. Shipping would be from 98036, WA. Link to comment Share on other sites More sharing options...
the.fedora Posted March 31, 2014 Author Share Posted March 31, 2014 PM sent Link to comment Share on other sites More sharing options...
