The EJ251 engine in my 2002 Forester weighs 119 kg (262 Lbs).
I had trouble finding this info online, so I thought that I would post it here.
I had taken the engine out to replace the clutch, and before resting the engine on the floor, I weighed it on my bathroom scales. Not exactly 100% scientific, but close enough.
The weight is for a bare engine:
- No oil;
- No coolant;
- No A/C pump;
- No Alternator;
- No Power-steering pump.
But includes:
- Flywheel and clutch;
- Timing-belt, all idlers and covers;
- Main drive-pulley;
- Rocker-covers and spark-plugs in place;
- Engine-mounts attached;
- Intake & Exhaust manifolds attached.
Edited by forester2002s
I would venture to say that weight is correct. The manifolds/mounts/flywheel probably add a good 75lbs by themselves. A friend and I pulled my ej255 without a lift and it was every bit of 300lbs with the intake and some accessories.
This was before my back injury too, there is no way in hell I would even consider it again.
Edited by Ibreakstuff
