colemanapp Posted April 3, 2014 Share Posted April 3, 2014 Hope this doesn't sound too stupid but I plan on adding 14"'s to my Loyale but only can find 4 wheels. Til I get the 5th, would 2 x 13's work as spares if I got a flat and changed both sides or do all tires front and back have to be same size? Its part time 4 wd. Link to comment Share on other sites More sharing options...
Silas Cruse Posted April 3, 2014 Share Posted April 3, 2014 13 will work but you will want to get a tire size close to the 14 use this http://www.tacomaworld.com/forum/tirecalc.php? to estimate the size. Close is good. Link to comment Share on other sites More sharing options...
wagonist Posted April 3, 2014 Share Posted April 3, 2014 It's only a spare. just make sure you put it on the back & leave the front ones as the same size. And obviously don't go driving all the way across the country with the spare on Link to comment Share on other sites More sharing options...
colemanapp Posted April 3, 2014 Author Share Posted April 3, 2014 Thanks for the quick replies and, Silas, that link is awesome for what I'm getting ready to do. Link to comment Share on other sites More sharing options...
turbosubarubrat Posted April 3, 2014 Share Posted April 3, 2014 A older friend i like talking to said when he was younger he had a lifted 80 toyota truck with 44 inch tires. He had a flat so he put on a spare which turned out to be the original so he put it on the front so it was leaning really far down on one front corn but he made it home. 1 Link to comment Share on other sites More sharing options...
RustyBrat Posted April 3, 2014 Share Posted April 3, 2014 A older friend i like talking to said when he was younger he had a lifted 80 toyota truck with 44 inch tires. He had a flat so he put on a spare which turned out to be the original so he put it on the front so it was leaning really far down on one front corn but he made it home. 44s on a 22r? was he insane perhaps? Link to comment Share on other sites More sharing options...
turbosubarubrat Posted April 3, 2014 Share Posted April 3, 2014 44s on a 22r? was he insane perhaps? If i share his subaru story here yes. 1 Link to comment Share on other sites More sharing options...
Ibreakstuff Posted April 3, 2014 Share Posted April 3, 2014 It's only a spare. just make sure you put it on the back & leave the front ones as the same size. And obviously don't go driving all the way across the country with the spare on If you have a rear LSD and you like the clutch packs working, run your offsize spare it the front where the open diff is. Link to comment Share on other sites More sharing options...
bratman18 Posted April 3, 2014 Share Posted April 3, 2014 44s on a 22r? was he insane perhaps? On a Toyota, you can change the gearing. Makes a world of difference. 1 Link to comment Share on other sites More sharing options...
RustyBrat Posted April 3, 2014 Share Posted April 3, 2014 I know but still... I donno i just wouldnt do it Link to comment Share on other sites More sharing options...
turbosubarubrat Posted April 3, 2014 Share Posted April 3, 2014 He put low gears in but the teeth would break. Link to comment Share on other sites More sharing options...
Phizinza Posted April 5, 2014 Share Posted April 5, 2014 Could always run it on the rear and take the right rear axle out like you do with a welded diff if its that much different and you have a long way to drive (over 60miles or).. Link to comment Share on other sites More sharing options...
