1979 Wagon Fuel Tank Help
You dont have to get a whole new tank, as long as it's not completely destroyed, you can use that handy dandy liner from Oreillys...
http://www.oreillyauto.com/site/c/detail/DAM1/REDKOTE/N2392.oap?keyword=fuel+tank+sealer&pt=N2392&ppt=C0126
It brought my seive-like 1977 Ford Courier fuel tank to better than new and good for a very very long time!
The steps I did:
1. Remove from vehicle and remove sender/hoses, etc...
2. Fill with water and drain cleaner or descaler *eats all rust and almost any gunk away* *BE CAREFUL and wear protection...*
3. Rinse out WELL and dry completely, I used a hair dryer
4. Make sure as much crap is knocked free
5. Repeat step 2 and 3 if necessary, interior should be shiny before sealer is used
6. Follow directions on tin
7. clean up any sketchy bits on the ouside and spray tank with a good undercoating/fuel proof paint
Notes:
dont forget to get the interior "ceiling of tank" clean
dont paint where you need cork to seal against steel
left over Red-Kote does not like to be kept, it tends to set once it hits oxygen.
