CMJAnew Posted April 13, 2014 Share Posted April 13, 2014 Folks, First understand I am NOT very good with a multi-meter. That is, I do a lot of touching this and that, not really knowing if I'm in the right spot(s). That said; when the key is in accessory position and/or the car is running, with wiper switch "ON" I can hear the motor "clicking" (doesn't really sound like arcing). when I touch the left (from the front) connection on the motor, the meter reads 11volts when I touch the right " " the meter reads 0 volts. Bad Motor???? Link to comment Share on other sites More sharing options...
RustyBrat Posted April 13, 2014 Share Posted April 13, 2014 i have the same problem Link to comment Share on other sites More sharing options...
Cyfun Posted April 14, 2014 Share Posted April 14, 2014 Have you tried disconnecting the wires going to it, and running wires directly from the battery? If that works, you might have a bad ground. If not, then it's likely the motor. Link to comment Share on other sites More sharing options...
CMJAnew Posted April 14, 2014 Author Share Posted April 14, 2014 I'll try running jumpers. Do I need to be careful of Positive and Negative? If so, which terminal on the motor corresponds? Link to comment Share on other sites More sharing options...
Uberoo Posted April 14, 2014 Share Posted April 14, 2014 pos or negative will just influence what direction it spins.Its just a motor afterall.While it may be clocked so it will spin one direction faster than the other way it should still move. 1 Link to comment Share on other sites More sharing options...
CMJAnew Posted April 14, 2014 Author Share Posted April 14, 2014 Using jumper wires directly from the battery to the wiper motor I got; tic-tic.......pause......tic-tic.......pause.......tic-tic No 'running' of the motor. Link to comment Share on other sites More sharing options...
Uberoo Posted April 15, 2014 Share Posted April 15, 2014 try taking the motor and gearbox apart and inspect it for damage.If everything checks out assemble it with new grease and try it again. Link to comment Share on other sites More sharing options...
CMJAnew Posted April 15, 2014 Author Share Posted April 15, 2014 Thanks, Bought a N.O.S. one. Link to comment Share on other sites More sharing options...
RustyBrat Posted April 15, 2014 Share Posted April 15, 2014 What did you pay? Link to comment Share on other sites More sharing options...
CMJAnew Posted April 15, 2014 Author Share Posted April 15, 2014 (edited) http://www.ebay.com/itm/220828882389?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 $56.00 including shipping. I think there is one more available. Edited April 15, 2014 by CMJAnew Link to comment Share on other sites More sharing options...
RustyBrat Posted April 16, 2014 Share Posted April 16, 2014 alright, thanks Link to comment Share on other sites More sharing options...
CMJAnew Posted April 19, 2014 Author Share Posted April 19, 2014 On 4/16/2014 at 2:13 AM, RustyBrat said: alright, thanks FWI - If you're interested in the other NOS wiper motor, the one I received works perfectly. Link to comment Share on other sites More sharing options...
