kirzick Posted April 17, 2014 Share Posted April 17, 2014 I'm buying a 91 loyal to make into a Wheeler. It currently has a 5spd pushbutton 4wd. I have a 4spd duel range out of a 84 gl I'd like to put in the loyal. How would I go about it? And yes I've tried searching. I know a 5spd duel range would be better but it's what I have. Thanks all. Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted April 17, 2014 Share Posted April 17, 2014 driveshaft length is different....4spd D/R box is longer than the 5spd box......you may have to play with the gearbox mounts....i ran a 5spd FT4WD D/R on ea81 4spd D/R mounts but i seem to remember it was it a fight to get things to fit/line up Link to comment Share on other sites More sharing options...
Gloyale Posted April 17, 2014 Share Posted April 17, 2014 On 4/17/2014 at 7:08 AM, kirzick said: How would I go about it? Bolt it in. The mounts shold land close enoguh to just put a few new holes in the crossmember. Fabricate a D/R shifter...... Use the 4spd one piece driveline. Then when you break the 4spd, which you will........Get a 5spd D/R and put all your 5spd stuff back in. 1 Link to comment Share on other sites More sharing options...
kirzick Posted April 17, 2014 Author Share Posted April 17, 2014 well that 4spd has lasted 350,xxxx miles so far. heres hopin it hangs on. Maybe ill go look around. What should i exspect for cost? Link to comment Share on other sites More sharing options...
