spicypeanut Posted April 19, 2014 Share Posted April 19, 2014 Is it possible to get an EA71 equip with a Weber Carb to pass emissions? I seem to have run into a wall. All my number are exceptional except for the HC. Which looks to be about 100PPM too high. Looking for guidance here. Link to comment Share on other sites More sharing options...
Subieguy Posted April 20, 2014 Share Posted April 20, 2014 Nope. It will not get through emissions here no matter what. Link to comment Share on other sites More sharing options...
spicypeanut Posted April 20, 2014 Author Share Posted April 20, 2014 I had it set to 4 degree BTDC timing, then when you connect the vacuum lines again it goes to 7 degrees BTDC. Still HC are up around 300. They need to be around 200 or so. Link to comment Share on other sites More sharing options...
Uberoo Posted April 20, 2014 Share Posted April 20, 2014 Try adding 2 oz of acetone per gallon of gas.Go to the testing place with 1/4 tank.if you pass fill up with normal gas to dilute the mixture because the acetone can degrade fuel lines and other rubber parts in short order. If the internet can be trusted people can get cars with performance carbs and no cats to pass with a little acetone.. Link to comment Share on other sites More sharing options...
Subieguy Posted April 20, 2014 Share Posted April 20, 2014 But you have to have all the emissions stuff in place on your car here in California. Part of their "visual" inspection. Link to comment Share on other sites More sharing options...
spicypeanut Posted April 21, 2014 Author Share Posted April 21, 2014 On 4/20/2014 at 9:32 PM, Subieguy said: But you have to have all the emissions stuff in place on your car here in California. Part of their "visual" inspection. I do have all the emissions equipment hooked up and it is all functioning properly. If the car came with a catalytic converter it would have passed already. The plan is to drive the car for the 30 days that I have the temporary operating permit for. Get the motor broken in, turn back the timing and air/fuel and then retest it. My mechanics say it should pass. And if not, I will either go back to the stock carb or add a cat to the exhaust. Link to comment Share on other sites More sharing options...
lvsarge Posted April 21, 2014 Share Posted April 21, 2014 Haha stupid California. Good luck man. Link to comment Share on other sites More sharing options...
Uberoo Posted April 22, 2014 Share Posted April 22, 2014 (edited) As far as cali visual test do you think the tester will be familar with what emmissions equipment where on a gen 1 brat in the first place.Its not like a 80's chevy that has a smog pump and a cat... Edited April 22, 2014 by Uberoo Link to comment Share on other sites More sharing options...
spicypeanut Posted April 22, 2014 Author Share Posted April 22, 2014 I was basically teaching the inspector about the car. Then he pulled out his tech spec book and looked up the car. Then he went so far as to google the brat to make sure that the dual exhaust was correct.... Link to comment Share on other sites More sharing options...
Uberoo Posted April 23, 2014 Share Posted April 23, 2014 next time shut your mouth. Link to comment Share on other sites More sharing options...
spicypeanut Posted April 23, 2014 Author Share Posted April 23, 2014 On 4/23/2014 at 12:24 PM, Uberoo said: next time shut your mouth. I didn't say anything. Just helping him understand that what he was looking at was hooked up correctly. Link to comment Share on other sites More sharing options...
Uberoo Posted April 26, 2014 Share Posted April 26, 2014 (edited) Like I said how that guy even know if everything was hooked up without you telling him what each thing was?If it passed and you didn't tell him anything he would just assume that everything is there and working correctly.You told him enough to undermine his position of power/knowledge, so to make him feel better he went for the book to double check what you said and find something you might have missed. Edited April 26, 2014 by Uberoo Link to comment Share on other sites More sharing options...
spicypeanut Posted May 13, 2014 Author Share Posted May 13, 2014 (edited) My Weber Carb equip EA71 (now with a catalytic converter) has passed the CA Smog test. No de-tuning needed. Edited May 13, 2014 by spicypeanut Link to comment Share on other sites More sharing options...
