bakerjr Posted April 21, 2014 Share Posted April 21, 2014 so i lifted my ea81 with maunal steering and i was wondering if anyone has came up with a good sterring adapter. i have read threads about ones with power sterring but it dont look like those ideas will work. on a second note what have you done for the shift linkage. i cant get it in to 2nd 4th or reverse. any ideas would be greatly appreciated. Link to comment Share on other sites More sharing options...
bakerjr Posted April 21, 2014 Author Share Posted April 21, 2014 before and after Link to comment Share on other sites More sharing options...
Gloyale Posted April 21, 2014 Share Posted April 21, 2014 Cut it in the middle of the rod, find pipe that fits snug over. Bolt in both ends with the pipe sleeved over the middle........Tack weld to set the length........then pull it back out and weld it up solid. It's good to have some water or at least a compressed air blowtip to cool the area near the joint after welding........so the heat doesn't burn out the grease and seals. Shifter I extended with a curved piece from a swaybar.........curve kinda "notches" around the rear of the shifter opening. Link to comment Share on other sites More sharing options...
bakerjr Posted April 21, 2014 Author Share Posted April 21, 2014 its a single u joint that isn't possible Link to comment Share on other sites More sharing options...
81EA81 Posted April 22, 2014 Share Posted April 22, 2014 (edited) Simply cut the shaft below the u joint. Edited April 22, 2014 by 81EA81 Link to comment Share on other sites More sharing options...
Gloyale Posted April 22, 2014 Share Posted April 22, 2014 On 4/21/2014 at 8:13 PM, bakerjr said: its a single u joint that isn't possible It is possible......many have done it........cut the splined portion off the top.......with enough shaft below it to sleeve into your extension tube.....Bolt the pieces in.....measure the sleeve.....insert sleeve.........double check all bolted in....then tack weld, remove, final weld...........done. Link to comment Share on other sites More sharing options...
