wagonman99 Posted April 24, 2014 Share Posted April 24, 2014 my power windows power locks radio dome light brake light and turn signals have all gone out. my brake switch was not getting any power so we ran a wire from my wipers to my brake switch and now it works. do you think this could be a bad fuse box, relay, or bad wiring? i need help pronto! Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 24, 2014 Share Posted April 24, 2014 Year? model? The fuses under the hood provide power to multiple sources inside the car. Need to check those first and the fusible link if your car has it. Link to comment Share on other sites More sharing options...
Cougar Posted April 27, 2014 Share Posted April 27, 2014 Use a test light probe to verify power to the fuses under the hood. If all the fuses are okay then you need to check the wiring beyond the panel. There doesn't appear to be a common fuse the areas you mentioned having trouble. Some folks have had corrosion trouble on the bottom side of the fuse panel. Link to comment Share on other sites More sharing options...
