krrz350 Posted April 26, 2014 Share Posted April 26, 2014 Hey guys and gals. I am having a problem with idling. The car runs great when accelerating ,but when shifting(4spd) or coming to a stop it wants to stall. It will also run like new sometimes, or like poop sometimes. The fuel tank has been cleaned, pump replaced, filters replaced, carb rebuilt and adjusted/tuned as well. What I have also found is there is a single wire valve on the front of the carb, when I beat on it the car will clear up. I am pretty sure that that is my culprit. So my real problem is locating the valve. Non of the parts stores can find it for me. Thanks in advance Link to comment Share on other sites More sharing options...
naru Posted April 26, 2014 Share Posted April 26, 2014 That is the idle stop solenoid. It cuts fuel to the idle circuit w/unpowered. You will need to find a used one. Since it is fubared anyway,I would unscrew it and cut or otherwise remove the pin that blocks the fuel passage. Might run on a bit at shutdown,but,that beats stalling. Link to comment Share on other sites More sharing options...
krrz350 Posted April 26, 2014 Author Share Posted April 26, 2014 Wonderful, I'll try "bypassing" it. Link to comment Share on other sites More sharing options...
naru Posted April 26, 2014 Share Posted April 26, 2014 Before doing anything drastic,I would put an ohmmeter across it(or power it up) and bash it around a little to confirm that it is indeed intermittent. Link to comment Share on other sites More sharing options...
krrz350 Posted May 2, 2014 Author Share Posted May 2, 2014 I took out the guts of the valve and unplugged it and my idle problem is fixed. Hooray!! Link to comment Share on other sites More sharing options...
