natetru Posted April 28, 2014 Share Posted April 28, 2014 1997 legacy gt wagon while sitting in my driveway checking for coolant leaks after a radiator swap, i start seeing tranny fluid start to drip, then run, then gush and spray ( about 20 seconds total while i look for source) then i see the rubber line back towards tranny has split..... my question is, i lost 1-2 quarts i guess. should i drop the rest of the fluid out and change filter since it is needing refilled. or am i better to leave what is left inside and just refill....anything else i should do while its down for this issue/ thanks in advance...... Link to comment Share on other sites More sharing options...
MilesFox Posted April 28, 2014 Share Posted April 28, 2014 Feel free to drain it, and then top off. However, don't bother with dropping the pan, since the 'filter' is just a screen, and you risk pan leaks going back together. Link to comment Share on other sites More sharing options...
natetru Posted April 29, 2014 Author Share Posted April 29, 2014 thank you very much....any additives reccomended for subarus? Link to comment Share on other sites More sharing options...
Rooster2 Posted April 29, 2014 Share Posted April 29, 2014 On 4/29/2014 at 12:00 AM, natetru said: thank you very much....any additives reccomended for subarus? No need for additives. Ordinary ATF works great. Link to comment Share on other sites More sharing options...
johnceggleston Posted April 29, 2014 Share Posted April 29, 2014 warning, the dip sticks can be hard to read, really hard to read. so fill it, check it, let it sit, check it again. and be sure you KNOW where the AT dip stick is. there is also a short one for the front diff. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 29, 2014 Share Posted April 29, 2014 (edited) I have a concern that the new rad may be leaking into the trans cooling coil. Or that coil is blocked? is that possible? which has more pressure at idle, the cooling system or the trans pump? just bad luck I guess since you only saw ATF but, check the radiator anyway. Edited April 29, 2014 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
natetru Posted April 29, 2014 Author Share Posted April 29, 2014 the fluid is absolutley clean...but i will pop radiator cap and check it also. i put a 4 inch lift on the car within last 50 miles, so i assume when i dropped notor/tranny i stretched the line that split... it is along driver fender near firewall....where rubber line connects to hard line. Link to comment Share on other sites More sharing options...
