1989 Subaru GL Wagon Acceleration Issues
Good morning all,
I just purchased a 1989 Subaru GL wagon.  I have been having some problems accelerating.  Sometimes while driving I step on the throttle and the engine seems to bog down.  it is similar to when you are in too high of a gear and try to accelerate hard.  The difference is when I step on the throttle the car actually goes slower and slower instead of faster.  When this first happened I pulled over turned the car off.  I started it back up, and it ran fine for awhile.  The same problem has come back randomly.  Any help on this would be great!
Thanks,
Lewis
  • 2 weeks later...
**UPDATE**
The issue causing the problem was a bad coil.  I had previously replaced all the maintenance/tune-up items which did not solve the problem.  Replacing the coil was the ticket...
