spicypeanut Posted May 1, 2014 Share Posted May 1, 2014 Hey all, I don't have much experience here but I was wondering if "upgrading" my old ignition coil would be a worthwhile upgrade. I have no idea what coil is on my car now. It has a black housing and while it visually looks fine and works fine, I was wondering if I might get a bit more power or more efficient burn if I was to replace it with something newer. Here are a couple I ran across while browsing online. Is this something that is worth upgrading? And if it is, is there anything I need to look out for when choosing a coil? These look to be nothing fancy: http://www.autopartswarehouse.com/details/QQSubaruQQBratQQReplacementQQIgnition_CoilQQ19781979QQREPO504601.html http://www.summitracing.com/parts/ado-e552c/overview/year/1979/make/subaru/model/brat "High Performance": http://www.summitracing.com/parts/acc-8140/overview/year/1979/make/subaru/model/brat Link to comment Share on other sites More sharing options...
djcommie Posted May 1, 2014 Share Posted May 1, 2014 Do you have the points or electronic ignition? Having a lower primary resistance (or higher amount of secondary windings) would increase the current draw on the driver/points and the increased load could overheat/corrode them, respectively. Unless you have a loss of power from weak spark/blowout specifically, you might not get any difference in performance/economy. For a street driven car with a generally stock engine, I wouldn't bother. I got absolutely nothing from my race car (not a Subaru) that had a weak stock igntiion system, replacing it with a MSD 6AL controller and Blaster SS coil. All it did was eat the distributor cap/rotor faster. I don't plan on replacing my original 1978 wagon's coil unless it exhibits weak spark issues. Note that it does have electronic ignition, which compared to points is probably a far more worthwhile thing to do over a bigger coil. Link to comment Share on other sites More sharing options...
cubastreet Posted May 2, 2014 Share Posted May 2, 2014 I've swapped to electronic dizzy and performance cool on my ea81. It runs beautifully but the distributor was the biggest improvement by far. Link to comment Share on other sites More sharing options...
