Front struts 86 GL
Anyone know where I can get "quick struts" for this?  I should replace both fronts.  I dont want to disassemble what I have now.  Or does someone rebuild them, etc?
I don't belive that a "quick strut" is available for the subarus.  Your best bet is to rent a spring compressor, and compress the spring to remove it from the old strut and install on new strut.
If you pull the struts yourself and take it to a small shop, they shouldn't charge you too much to swap cartridges into your struts. I think I paid $25 to have a pair done but that was seven years back.
Just did this a few weeks ago and it was fifty. Could have probably done a little better had I called around, but I needed it "now."
Dan
