bb1994legacyguy Posted May 4, 2014 Share Posted May 4, 2014 Greetings, I am a first time poster. I put new rear struts on my 94 2wd legacy wagon 5spd in October '13. After installing them I found the NAPA store sold me struts for a '95 that wouldn't work. After getting that straightned out I bought struts from an Advance store. They worked but after a few months a rear brake flexible line blew and luckily I was not in a situation where I had to stop the car in hurry. I found the flexible line on both struts had pulled out of the mount on the strut and that caused one of them to tear after rubbing against something. I am beginning to wonder if I got the struts reversed. They are installed so the mount for the flexible line is towards the rear of the car. If the struts are switched to the other wheel the mount will be on face the front of the car. I thought I checked with the store and got them right. Also the original struts had a enclosed hole for the flexible hose to fit through. The replacement has an open end. Does anyone know if the mount faces the front of the car or the rear when installed? This has been going on for 6 months and is still not straigtened out. Thanks Ben <script charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript"> </script> Link to comment Share on other sites More sharing options...
Txakura Posted May 4, 2014 Share Posted May 4, 2014 I see the line was twisted during installation and there is a pre-load on it. However, I cannot comment on the strut position. I am hopeful someone will be along shortly for that. Link to comment Share on other sites More sharing options...
Fairtax4me Posted May 4, 2014 Share Posted May 4, 2014 The mount should be on the same side as the caliper. It looks like the mount opening on that strut is spread open. Some struts have open end mounts so that you don't have to disconnect the brake hose to replace the strut. Kinda lazy if you ask me, especially since strut replacement is a good time to flush the brake fluid. Just squeeze the ends closer together with a pair of pliers. You may want to buy new line clips to help keep the line in place. I've seen people use large zip-ties wrapped around the strut to keep the hose in the mount. Link to comment Share on other sites More sharing options...
lmdew Posted May 5, 2014 Share Posted May 5, 2014 The metal fitting in the center of the line should be inside the struct bracket, not on top of it. Easy fix. Yes the strut is installed correctly. Link to comment Share on other sites More sharing options...
