WASHroad Posted May 5, 2014 Share Posted May 5, 2014 Stared looking AKA E-Bay for engine gasket set I will be needing on my '91 Loyale. Not a whole lot of price difference for the most part 45-65 most sets.. Brands like Eristic and Misumo seem to be on there the most. Are these all on par with each other or is there some nasty stuff to stay away from.. I know OME is the best, and I haven't priced them yet, I was looking for some guideance. Aftermarket stuff or spend the $$ for OME.. Anyone know what Subaru gaskets sets run on that note.. Thanks Link to comment Share on other sites More sharing options...
MR_Loyale Posted May 5, 2014 Share Posted May 5, 2014 (edited) I am in the exact same boat. Those that have experience in this please chime in. Are you doing your HG too? HLA's? Edited May 5, 2014 by MR_Loyale Link to comment Share on other sites More sharing options...
jono Posted May 5, 2014 Share Posted May 5, 2014 Genuines were under 30 bucks each at subarupartsdepot.com Link to comment Share on other sites More sharing options...
idosubaru Posted May 5, 2014 Share Posted May 5, 2014 (edited) 1. Subaru 2. Fel Pro permatorque gaskets (these don't require a retorque) i'd avoid the cheap gasket sets. i've seen headgaskets fail and EA82 crank seals be the wrong size (too big). folks have even measured and put pictures online of the differences in sizes. 1. head gaskets 2. intake manifold gaskets from Subaru (flimsy cardboard aftermarkets will leak coolant into the heads) 3. reinforced cam carrier oring (2) from Subaru. do not use a regular oring - has to be metal reinforced. that's the bare necessities, exhaust manifold gaskets are often reusable if they're original OEM and not too degraded/rusted. valve cover, crank seal, oil pump seal, oil pump oring, oil pump gasket, cam seal, cam oring rockauto, amazon Edited May 5, 2014 by grossgary Link to comment Share on other sites More sharing options...
Gloyale Posted May 7, 2014 Share Posted May 7, 2014 Stone HG sets FTW Link to comment Share on other sites More sharing options...
rdweninger Posted May 7, 2014 Share Posted May 7, 2014 Okay... maybe I'm old. What is FTW? But GLoyale... do you mean Stone HG sets are good or bad? 1 Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted May 8, 2014 Share Posted May 8, 2014 it means 'For The Win!' and ive heard stone HGs are pretty good compared to most Link to comment Share on other sites More sharing options...
MR_Loyale Posted May 8, 2014 Share Posted May 8, 2014 1. Subaru 2. Fel Pro permatorque gaskets (these don't require a retorque) i'd avoid the cheap gasket sets. i've seen headgaskets fail and EA82 crank seals be the wrong size (too big). folks have even measured and put pictures online of the differences in sizes. 1. head gaskets 2. intake manifold gaskets from Subaru (flimsy cardboard aftermarkets will leak coolant into the heads) 3. reinforced cam carrier oring (2) from Subaru. do not use a regular oring - has to be metal reinforced. that's the bare necessities, exhaust manifold gaskets are often reusable if they're original OEM and not too degraded/rusted. valve cover, crank seal, oil pump seal, oil pump oring, oil pump gasket, cam seal, cam oring rockauto, amazon For Subaru are you talking a complete gasket set or just the HG? Link to comment Share on other sites More sharing options...
