el_freddo Posted May 24, 2014 Share Posted May 24, 2014 Have you checked your timing marks since you put the engine in? id try resetting the ECu once pull the pos cable and let it sit. My thought was trying to reset the ECU too. Don't forget that you shouldn't touch anything for the first 5 minutes after starting to let the ECU work out it's parameters. Having the second O2 sensor would help out too. My other thoughts are that your fuel pressure regulator might be stuffed. Or there is something between the donor vehicle and this one that you're missing. It really is a guessing game without being near the vehicle to physically check it out All the best (subscribed) Bennie Link to comment Share on other sites More sharing options...
bratman18 Posted May 24, 2014 Author Share Posted May 24, 2014 Yeah we thought resetting the ecu would help too, but we have tried it a few times with no good results. And as I said, we even tried my ECU in a known running car, and it powered the car flawlessly. While the second o2 sensor may help it run a bit better, it should not affect it in this way, and keep it in limp mode. And at this time, without being able to drive it to the exhaust shop, there is no where to put the second o2. I guess we could check the fuel pressure regulator, but we did check the fuel pressure and it all checked out. I will definitely take a video of what it's doing the next time I'm there. Thanks guys Link to comment Share on other sites More sharing options...
czny Posted May 24, 2014 Share Posted May 24, 2014 (edited) Not the FSM but a Haynes book fuel system procedure, for anyone who needs it: Edited May 24, 2014 by czny 1 Link to comment Share on other sites More sharing options...
bratman18 Posted May 26, 2014 Author Share Posted May 26, 2014 We're going to try swapping the intake manifold out. He has seen this one other time, the swapped the intake manifolds, and it fixed the problem. Obviously it was something on or in the intake that wasn't working right, but it makes it hard when everything tests out ok, and it doesn't throw any codes. But I'm taking a break from it. I'm beyond frustrated because of what I have put into this swap, and the fact that it isn't at all driveable is quite frustrating. Link to comment Share on other sites More sharing options...
bratman18 Posted May 26, 2014 Author Share Posted May 26, 2014 If we cant figure this out, could I change the harness and intake manifold out for an OBD1 set up and have it work? Are those not as finicky? Link to comment Share on other sites More sharing options...
Gloyale Posted May 30, 2014 Share Posted May 30, 2014 If we cant figure this out, could I change the harness and intake manifold out for an OBD1 set up and have it work? Are those not as finicky? If all else fails I'll trade you an OBD I harness and ECU for the 96 setup. I want you to have a runnig EJ. Link to comment Share on other sites More sharing options...
bratman18 Posted May 30, 2014 Author Share Posted May 30, 2014 If all else fails I'll trade you an OBD I harness and ECU for the 96 setup. I want you to have a runnig EJ. Thank you. Definitely means a lot. Link to comment Share on other sites More sharing options...
bratman18 Posted June 1, 2014 Author Share Posted June 1, 2014 Got a video of what it does. Ej swap issue: Link to comment Share on other sites More sharing options...
Gloyale Posted June 1, 2014 Share Posted June 1, 2014 It says " this video is private" Link to comment Share on other sites More sharing options...
el_freddo Posted June 1, 2014 Share Posted June 1, 2014 It says " this video is private" Same for me Cheers Bennie Link to comment Share on other sites More sharing options...
bratman18 Posted June 1, 2014 Author Share Posted June 1, 2014 (edited) Grrr. Should be all set now. Here it is again, and me feathering the throttle after i try to rev it, is just to smooth it out so that it'll idle again. Edited June 1, 2014 by bratman18 Link to comment Share on other sites More sharing options...
el_freddo Posted June 2, 2014 Share Posted June 2, 2014 There's a weird metallic noise I can hear, particularly when you rev it up and it plateaus. I'm wondering if this is messing with your knock sensor. Also, what exhaust are you running - that's not restricting the engine is it?CheersBennie Link to comment Share on other sites More sharing options...
bratman18 Posted June 2, 2014 Author Share Posted June 2, 2014 There's a weird metallic noise I can hear, particularly when you rev it up and it plateaus. I'm wondering if this is messing with your knock sensor. Also, what exhaust are you running - that's not restricting the engine is it? Cheers Bennie Yeah it does seem to knock a bit when it starts bogging out. But no knock sensor code. And It's a new knock sensor. The exhaust is an inferno fab single exhaust port UEL header, then it has a 2.5" flex pipe welded to that, and then it just has a muffler clamped on that. It doesn't even have a full exhaust on it yet because we couldn't drive it to the exhaust shop. Link to comment Share on other sites More sharing options...
Carl B. Posted June 17, 2014 Share Posted June 17, 2014 I see you still have the ea82 fuel pressure regulators in the fuel line. The ej should have a fuel pressure regulator in the fuel rail. Not sure but that could be an issue. Link to comment Share on other sites More sharing options...
bratman18 Posted June 17, 2014 Author Share Posted June 17, 2014 Those aren't fuel pressure regulators, they are just silencers so to speak. But they will be removed soon enough, at least the one in the feed line. Just haven't worked on it in a few weeks. But the fuel pressure has been tested, and tested good, so I dunno. Link to comment Share on other sites More sharing options...
bratman18 Posted June 26, 2014 Author Share Posted June 26, 2014 Removed the silencers and swapped a known good intake manifold off a running car. Still does the same thing. There is literally nothing else left to try with this set up. Link to comment Share on other sites More sharing options...
Gloyale Posted June 26, 2014 Share Posted June 26, 2014 Timing marks used not arrows? When you resealed engine.....Did you have heads off? the rockers off? any chance you've got a tight valve? Just seems like something in the engine to me. I will send another harness if you need it just be nice to check everything else first. Link to comment Share on other sites More sharing options...
bratman18 Posted June 26, 2014 Author Share Posted June 26, 2014 Timing marks used not arrows? When you resealed engine.....Did you have heads off? the rockers off? any chance you've got a tight valve? Just seems like something in the engine to me. I will send another harness if you need it just be nice to check everything else first. Yeah timing is definitely on where it needs to be. We did have the heads off, but didn't touch the valves or anything, and it ran perfect literally hours before resealing it. We've spent hours and hours going through everything that it could be. I have a fair amount of knowledge when it comes to Subarus, but my friend who owns a garage, is known as the Subaru Guru in the area. He works on these cars every day and can't figure it out. Link to comment Share on other sites More sharing options...
Hsoj Posted July 7, 2014 Share Posted July 7, 2014 Try adding extra grounds or separating out your ground lines so you're not getting feedback up some line. I remember that was an issue with my swap. Link to comment Share on other sites More sharing options...
bratman18 Posted July 7, 2014 Author Share Posted July 7, 2014 That was actually already done. At this point the harness is pulled out. Link to comment Share on other sites More sharing options...
Gloyale Posted July 16, 2014 Share Posted July 16, 2014 Okay....Update Bratman shopped me the OBD II harness. I used it to run an engine at my shop.......all worked well, until I tried using the MAF he sent back too........Engine hiccuped, popped and basically acted just like the engine in his video. Hooked up that MAF to another running harness.....and it then worked??? Well I checked the condition of the contacts at the MAF and on the Harness plug... One of the MAF pins had a thick black buildup of carbon.....and it's corresponding "female" mate in the harness was a bit loose too......Cleaned them off, pinched the connector a bit....VOILA! It's all working great...... Bratman, I'll post a video. The ones I shot yesterday will not import with sound??? WTF?? Stupid iPhone4 (that's been , run over, crushed and then sank to the bottom of a river) I'll shoot another one today with the Ipod Nano....it takes good video... 1 Link to comment Share on other sites More sharing options...
bratman18 Posted July 19, 2014 Author Share Posted July 19, 2014 I really hope that's all it was. We did try another maf with the same results, but I suppose if the connector had a bad spot, that'd be why that didn't work either. Can't wait to get this done! Whenever I finally get home from working in Canada anyway. Link to comment Share on other sites More sharing options...
bratman18 Posted September 29, 2014 Author Share Posted September 29, 2014 Bump this up. Any more ideas? Link to comment Share on other sites More sharing options...
Crazyeights Posted September 30, 2014 Share Posted September 30, 2014 Still not fixed yet? Link to comment Share on other sites More sharing options...
bratman18 Posted September 30, 2014 Author Share Posted September 30, 2014 Nope. Still does the same exact thing. Runs perfect, except won't rev over 4k rpms. Link to comment Share on other sites More sharing options...
