Hey Im having a conundrum. I want to add a turbo kit to MY97 Imp OBS 2.2. Found a killer deal :D  Anyways, I did some research but it looks like the front cat is deleted. Is this accurate? I just bought a new Magnaflow front cat. Im also getting some EL headers. Will all of this work together, without having to delete the cat? Thanks.
Well its not a computer so I'm not sure how you just "delete" it?
The stock turbo setups the cat pipe runs up to bolt onto the back of the turbo and the first cat is almost directly off the back of the turbo. Second cat is in a similar placement as the NA engines.
Your setup with the kit may vary. You may have to get a down pipe made, or you may be able to bolt in a stock down pipe from a WRX.
