MR_Loyale Posted May 9, 2014 Share Posted May 9, 2014 (edited) I pulled my EA282 yesterday. I took the opportunity to inspect the clutch, throwout bearing and pilot bearing I installed in 2006. The pilot bearing felt rough. Not sure how that happened. It was the one included in the clutch kit I bought at the time. I am wondering if I did something wrong in installing it. If so, now is the time to find out what I messed up and do it correctly. The only problem I can recall is that the new clutch would occasionally "chatter" when accelerating from a stop. I just figured it was seating. I did have the flywheel surfaced last time. So now I get to take off the pressure plate and dig the pilot bearing out. May just put another new clutch in. Is this a case of getting an original Subaru pilot bearing is the best option? Or should I see if they have a clutch kit? Edited May 9, 2014 by MR_Loyale Link to comment Share on other sites More sharing options...
rdweninger Posted May 9, 2014 Share Posted May 9, 2014 I like the Japenese-made bearings. I have had excellent results with NSK. Timken is US-made. NTN is good. The Chinese bearings are getting better.... but. Avoid India and other Asia brands. Careful how you put it in... only press (or tap) on the outer race. 1 Link to comment Share on other sites More sharing options...
idosubaru Posted May 10, 2014 Share Posted May 10, 2014 I like the Japenese-made bearings. . +1 until you find some compelling reason otherwise, stick with Japanese bearings, particularly for anything crucial or time consuming like a pilot bearing. Link to comment Share on other sites More sharing options...
