93 loyale....how to check CEL light
Hey men
Whats the procedure for checking for a code?  It's been a long time
I recall a connector under the dash...that's all
I think my problem is going to be and ecr solenoid (checked it 2 years ago and want to try and fix it before I sell it)
this baby has 54,000 original miles,,,,,interior is like new...body nice
This stuff can be confusing as heck at first... Not sure if your car is the same setup as mine(there are some differences between years), but I own a 90 Loyale and successfully checked codes recently. On mine, there are two connectors inside the engine bay, right on the drivers side firewall. One is green, and the other is white. They ought to be unplugged when you find them. You need to plug the green one in to get codes to flash. The flash occurs under the steering wheel, directly from an LED light on the ecu. You have to take off the panel under the steering wheel to see it. Takes some figuring out. Let me know if that helps
