d8usti5n Posted May 13, 2014 Share Posted May 13, 2014 Been looking into getting 15 inch rims for my 1980 brat, so I have more tire options. Has any one here ever put 15's on a 1st gen without a lift? Any clearance issues, or any other issues? Link to comment Share on other sites More sharing options...
spicypeanut Posted May 13, 2014 Share Posted May 13, 2014 I'm following this, I've been wondering the same thing. Apparently my tire guy said the biggest tire I can put on my 13" wheel are 175/70/13. Which is pretty weak. Link to comment Share on other sites More sharing options...
turbosubarubrat Posted May 13, 2014 Share Posted May 13, 2014 15's can fit without a lift and it has been done before you just need low profile tires. 1 Link to comment Share on other sites More sharing options...
ironworkerboomer Posted May 13, 2014 Share Posted May 13, 2014 (edited) I used 14 inch. The same size in a 15 would have been an inch taller and as you can see with no lift its full with the 14 and as soon as I money up getting these same size as pictured above BFGoodrich All-Terrain T/A KO Tire LT195/75R14 Just my 2cents compare with the stock 13 Edited May 13, 2014 by ironworkerboomer 1 Link to comment Share on other sites More sharing options...
turbosubarubrat Posted May 14, 2014 Share Posted May 14, 2014 Link to comment Share on other sites More sharing options...
bendecker Posted May 14, 2014 Share Posted May 14, 2014 I have 14's on my 1981 (pug steelies) with 185/75/14 (about 3 inches larger than stock). They needed 1/2 spacers in the rear and longer lugs to miss rubbing on the torsion bars, though. Both are readily available on Ebay and elsewhere, but you'll probably need to drill a couple of holes in the spacers to make them work with our odd lug pattern. 1 Link to comment Share on other sites More sharing options...
