joe5 Posted May 14, 2014 Share Posted May 14, 2014 Hey there I'm new to the forum (and working on cars in general). I need a replacement rear brake drum for my 4WD 92 loyale. The local junkyard only has 2WD loyales right now so the drums won't work. However, they do have a GL on the lot. Will the GL brake drum fit my loyale? Thanks in advance. Joe Link to comment Share on other sites More sharing options...
TallonX Posted May 14, 2014 Share Posted May 14, 2014 DL GL GLF GL10 all packages Year break is what is important, square body, ea82, 4WD, 86+ You can ask the junkyard to cross reference parts for clarification or you can goto a major supplier's website and do it yourself Link to comment Share on other sites More sharing options...
joe5 Posted May 14, 2014 Author Share Posted May 14, 2014 Thanks for the quick response. Yea the GL is an 87, non turbo. Not sure about whether its an ea82 or 81... I'll make sure its an ea82 when I go back to the yard today before I take the drums. Link to comment Share on other sites More sharing options...
bratman18 Posted May 14, 2014 Share Posted May 14, 2014 First year of ea82 was 85 fyi. So any 4wd ea82 non turbo will have rear drums that will fit. 85-94. Link to comment Share on other sites More sharing options...
joe5 Posted May 23, 2014 Author Share Posted May 23, 2014 (edited) So I got the drum and threw it on the car just to get things moving but it has some wear that's got me a little concerned... It has some abnormal wear on the outside of the part that fits the spindle (sorry I don't what that parts called). I should have taken a picture of the actual brake drum but I did make this little picture to show what I'm talking about. http://s1248.photobucket.com/user/sextond1/media/brakedrum_zpsd903a420.jpg.html?sort=3&o=5 The surface where the red arrow is pointing is worn down allot. Is this a big deal? It still seats on spindle fine and ive drove it around a day or two with no problems, I just wonder if this surface is important for keeping brake dust out of the wheel bearing and I've created a future problem for myself... Edited May 23, 2014 by joe5 Link to comment Share on other sites More sharing options...
MilesFox Posted May 23, 2014 Share Posted May 23, 2014 there will be a natural wear mark where the seal engages it. any more wear would be clue to a failed wheel bearing or loose axle nut, or improperly installed washer on the axle nut. the flat washer is a spring washer, convex, with the convex side against the nut, and the concave side against the cone washer Link to comment Share on other sites More sharing options...
joe5 Posted May 23, 2014 Author Share Posted May 23, 2014 So although the wear on the drum indicates the previous car had some issue (failed wheel bearing or loose axle nut), is it likely to be the source of a future issue? Link to comment Share on other sites More sharing options...
MilesFox Posted May 23, 2014 Share Posted May 23, 2014 if the bearing is failing, the wheel will have negative camber, and thhe drum will be skewed vs the shoes, causing uneven wear or curtting grooves in the drum. I would investigate replacing the wheel bearings, and replace the axle nut hardware. for what the trouble is worth, take toe opportunity to convert to disc brake. in regard to the bearing, it's actually less work to swap the whole control arm, brake and all, with a known good unit Link to comment Share on other sites More sharing options...
joe5 Posted May 23, 2014 Author Share Posted May 23, 2014 Yea but while the bearing may have failed on the jy car i pulled the drum from, the wheel bearing is brand new on my car as I just replaced it. So I have no reason to think there is problem with my bearing or hardware (yet ha, unless my jy brake drum changes that situation...which is what im getting at with my question). Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted May 24, 2014 Share Posted May 24, 2014 I agree with Milesfox... use this opportunity to swap to rear disk brakes. You can find them on the rear of an 85-90's turbos. If you are 4WD, get them off a 4WD. Link to comment Share on other sites More sharing options...
