Danja44 Posted May 15, 2014 Share Posted May 15, 2014 I am getting a bit of a tapping sound like valves or almost a dieseling noise under acceleration with a load. Also, its been running lean since I've owned it. The plugs come out white. Any Ideas?? Link to comment Share on other sites More sharing options...
TallonX Posted May 15, 2014 Share Posted May 15, 2014 Timing set a 8°BTDC? Link to comment Share on other sites More sharing options...
djellum Posted May 16, 2014 Share Posted May 16, 2014 probably spark knock. its common for people to jack up the timing so double check it. if you know its running lean then that can cause it as well, you probably need to clean and adjust the carb. put some 92 octane in it and see if the noise changes. Link to comment Share on other sites More sharing options...
Danja44 Posted May 16, 2014 Author Share Posted May 16, 2014 I'll double check the timing when I do the valves this weekend. I know the carb is clean, I rebuilt it about a month ago and cleaned it up really good. Couldn't get the jets out so I just blew them out as best as I could. Would a plugged up exhaust play a role in it running lean? Link to comment Share on other sites More sharing options...
Subruise Posted May 16, 2014 Share Posted May 16, 2014 ea82s have hydaulic lifters and do not require valve adjustments. make sure youre not a tooth off on the tbelt. if not, time for seafoam 1 Link to comment Share on other sites More sharing options...
Danja44 Posted May 17, 2014 Author Share Posted May 17, 2014 Awesome! I didn't wanna check valves clearances anyways! Haha. I'll be sure to check all the timing marks this weekend. Thanks! Link to comment Share on other sites More sharing options...
