Hi, Im new to subaru's and new to driving a manual too,(never going back ;) ).I have a 1997 subaru impreza outback that needs a little TLC and I  need some ideas about what and how to fix the problem that my car is experiencing. There is a rubber on rubber squeaking sound from the front left wheel when I turn left and speeds of 40 mph or less. I have replaced the inner and outer tie rods,front left brake caliper ,rotors and pads on the front left and right ,struts,and replaced the bad hub,bad wheel bearings with a used hub. New serp belt and powersteering belt?(two belts at the front) Again, its only on the front left and only noticeable at speeds under 40 mph and when I make any kind of left turn.Alignment is fine,tires good.Oh yeah,its only after the car has been driven for a fewmiles.What could it be????
Edited by rete
dunno why it would be directionally biased, but maybe the crank pulley is starting to separate/wobble?
could the strut mount be squeaking?
maybe debris behind brake dust shield ?
do you mean there's squeaking AS you turn the wheel? or, DURING the turn as the car moves with the wheels turned?
Edited by 1 Lucky Texan
  • 4 weeks later...
Replaced the front left cv axle with a brand new one.I have used forester struts on the front passenger and driver side.The rubber squeaking and chirping is gone,but what remains is a tick tock click sound from the front left wheel area at under 3rpms.Im not sure if it goes away after 3 rpms or if my muffler noise drowns it out at higher speeds.(and much more noticable as your driving rather than walking alongside) ????????????????/
Edited by rete
