What went wrong here?
I am posting the forensic evidence so that hopefully someone can see something that was done wrong. 43K ago I put in a new pressure plate, clutch, pilot bearing and even took the flywheel off to have it surfaced. Oh and I replaced the rear main seal too for good measure.
So now I have the engine out and I put my finger into the pilot bearing hole and it has a grinding feel. Then I get the pressure plate off and I see score marks on the clutch disc, pressure plate and flywheel. I know there were no contaminants on either the pressure plate, flywheel or clutch because I used surgical gloves and it was cleaned with brake cleaner prior to install.
However I did occasionally have clutch chatter.
What went wrong? I don't want to make the same mistake twice!
And what is up with the grease in the bell housing? I replaced the rear main seal 43K ago. Could the transmission be leaking this? It is also all greasy inside and I cleaned very well 43K ago.
hi,
  not too sure about the marks, but i've seen some clutch discs have short strands of what appear to be brass wire imbedded in the fiber of the disc, factory not accidental.
 as for the oil , if your motor has that metal plate cover on the back of the block, it's behind the flywheel,  the gasket on those are bad to seep or outright blow oil ,, it's a area that is subject to crankcase pressure, so if the pcv system has any abnormal pressure it tends to force oil vapor out the weakest place??  and i've never encountered one of those covers that the screws were not just finger tight. i think they get loose as the gasket shrinks or maybe it's the planned obselessence thing at work by having a cover that is bound to leak in a couple of years time.
Yup, I got an oil leak to fix, I think that is established. But the question is this from the transaxle (which is also covered on the inside) or the engine.
OK so I removed the flywheel and there are no plates back there, just two big honking hexagonal keyed plugs that I think are used during assembly of the pistons to access the wrist pin clip thingies. One appear to perhaps be leaking. Gonna do the UV light tonight to be sure.If no glow is there then it is definitely from the transmission. Pics soon to follow.
Edited by MR_Loyale
Other than the leak, I don't see anything "wrong".....that's not even a terribly worn clutch.....just used for 43k miles.
The pilot bearing was all munged up. You go to turn it and it is like there is sand in it. Maybe that cause the clutch marks?
Looking at the first picture it looks to me that the oil may be coming from above, though the seal may be leaking also. Notice the dark plug at the top of the picture and the way the oil seems to have a cleaner path way possibly due to the fresh oil coming down. How does the area above that look for signs of oil? I suspect the plug on the left just has a ridge where oil can collect and isn't really leaking from there.
I'm gonna bet it's an input shaft seal. They're super cheap on Amazon. You'll have to split the transmission case but that's not as bad as it sounds. I've never had one that didn't leak after taking it apart though, but I'm a sucky mechanic.
The area on top of the block just above is bone dry clean.
Check the flywheel depth all around especially comparing the darker areas to the lighter. Straight edge and dial calipers would do. It looks to me like the flywheel wasn't surfaced parallel to clutch cover surface.
Ask me how I know....had the same kind of chatter a few years ago after a rebuild & it was a badly ground flywheel. :mad:
HOLY CRAP! That never occurred to me.  That would definitely munge the pilot bearing too wouldn't it?
Sure would. Imagine the whole assembly, clutch cover & disc, oscillating in & out against the TO bearing.
The friction disc being flexed on the input shaft splines while the pilot bearing is struggling to keeps things aligned.
Mike the friction disc all around to see if the lining is still even. If its thinner toward the outside than the center then pressure wasn't applied evenly - un-square flywheel.
Edited by czny
  • Like 1
