1992 Loyale wagon,
Can somebody hep me out  on finding a oil pump assembly pdf  with exploded view for a 1.8L.It's a little plug at the bottom of  the oil filter that started leaking on mine and I need to see what is the part so I can removed it and replace it.It looks like it might be some kind of of freeze plug??????
Anybody has had any experience on fixing this issue and what did you do to fix it.Thank you.Bill. :)
BillN1ass@gmail.com
Did they even try? Some dealers won't be bothered and others will go out of their way. If they didn't at least look up the part number and check the system they blew you off. Don't let them tell you they can't get parts for a loyale cause they can.
