ghoti Posted May 22, 2014 Share Posted May 22, 2014 My 82 wagon has dr 4sp and won't shift into reverse. Any way to shim the linkage or something to get it over there? Quote Link to comment Share on other sites More sharing options...
skishop69 Posted May 22, 2014 Share Posted May 22, 2014 Does it try to shift? Does it grind? Does it go part way in at all? I doubt it's a linkage problem if all the other gears work fine. It's probably internal. There are no linkage adjustments. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted May 22, 2014 Share Posted May 22, 2014 Try this one: http://www.ultimatesubaru.org/forum/topic/47562-fix-for-worn-and-sloppy-shifter-linkage/?hl=sloppy Quote Link to comment Share on other sites More sharing options...
ghoti Posted May 22, 2014 Author Share Posted May 22, 2014 It feels like the shifter isn't going far enough to the right, but it has play on it. Not a super tight shifter, but I end up in 4th, no matter how far over I go with it. It happened gradually, so I thought it might be something getting loose. Quote Link to comment Share on other sites More sharing options...
ghoti Posted May 22, 2014 Author Share Posted May 22, 2014 Thanks,Shawn I'll give it a try. Quote Link to comment Share on other sites More sharing options...
skishop69 Posted May 22, 2014 Share Posted May 22, 2014 (edited) Yep, I think Shawn is right based on your last post of the slop. Also, the bushing that holds the stick in the mounting 'shelf' can go bad as well. I think GD had a fix for that. Edited May 22, 2014 by skishop69 Quote Link to comment Share on other sites More sharing options...
wagonist Posted May 23, 2014 Share Posted May 23, 2014 Tried following the links above, but it ended up at a bad page... The shifter bushes go bad all the time in these. They gradually wear away over the years, and people just get used to it gradually getting sloppier. The bushes are hidden away, so you mostly don't see them even when working on the car, and hence forget about them. Remove the centre console & then unscrew the rubber boot off the floor & you should see them. Also on the back of the gearbox Quote Link to comment Share on other sites More sharing options...
