Mounting fog lights to 3rd gen bumper?
I've got my bumper completely apart and will be cleaning up and "rust controlling" the various pieces, but while it's apart it got me thinking.....
How is everyone mounting their fogs to the bumper? The actual metal bumper doesn't extend far enough out to offer a surface, all that is up front under the plastic cover is.......
STYROFOAM.
I see no way of rigidly mounting the fogs above or below the bumper line; perhaps I'm missing something?
My fog lights below my bumper (and my offroad lights on top) are just screwed into the bumper. They don't go all the way through, but yet they're quite securely mounted. They don't vibrate or anything. It's stronger than you'd think.
I made brackets that clip onto the cut outs in the back of the bumper metal. And then they bend and go under the little metal strip under the grille, and my lights are mounted to that. That way you can take them off and you don't have holes in your bumper.
Could you explain it a little more in-depth, maybe with pictures, JJ?
Wow, didn't see this until now. I can get you pictures in the morning if you'd like. Though really all it is are two 2" long self-tapping screws holding each light. Just drilled them in to get 'em tight, then that was that. They're just drilled straight into the bumper.
The mounting brackets for the lights I have allow me to do this. My old light setup I had to get a bit creative. I bought a door hinge at ACE Hardware and used that as a bracket, but it drilled directly into the bumper in the same fashion. Just a screw straight into the styrofoam. I have some pictures of my old setup in the following thread (post #13):
http://www.ultimatesubaru.org/forum/topic/134769-ea82-alternator-upgrade/?do=findComment&comment=1133181
I'll get some pictures of my new setup in the morning.
Edited by jj421
