angerthis Posted May 23, 2014 Share Posted May 23, 2014 do any of you have vacuum diagrams for my 1986.1 Rx like turbo and evry thing els under the hood? Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted May 24, 2014 Share Posted May 24, 2014 Have you tried looking at a Hayne's or a Chilton's book for vac diagrams? Anything specific, or just everything vacuum related? Haha Link to comment Share on other sites More sharing options...
angerthis Posted May 24, 2014 Author Share Posted May 24, 2014 manly just 4 my turbo like waste gate vacuum line goes were? and how would i go about hooking up a boost gauge to my turbo this is my first turbo car iv had and it being a 1986.1 RX i could have not pick a more one off car if you know what i am saying LOL but true and i all ready blow my head gasket ones and would like to not do it a gen right now i am running it with out the turbo and it sucks i wont to put it back in just dont like making the same mistake a second time Link to comment Share on other sites More sharing options...
jono Posted May 24, 2014 Share Posted May 24, 2014 I can see in my minds eye these little IHI turbos already off an EA82T with its wastegate vacuum/pressure line self contained sort of thing ? Goes from an outlet on the turbo to the waste gate levers diaphragm - yeah ? That is a factory non valve adjuster in the mix ..... Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted May 24, 2014 Share Posted May 24, 2014 Yeah, the wastegate actuator vac hose goes from the wastegate to the outlet side of turbo, on the pre-87.5 I believe its just a hose about 2-3 inches long. On mine, which is an 87.5 EA82T those hoses go to a boost selenoid on passenger side strut tower first instead of just going from wastegate to turbo outlet. And I have a boost gauge set up off the intake manifold from where an old sensor was, or you can just T in at any vac line off manifold. Anywhere on the manifold after throttle body will be a good place to show boost pressure. Link to comment Share on other sites More sharing options...
angerthis Posted May 28, 2014 Author Share Posted May 28, 2014 so what is this? and do i run any vac hose from turbo 2 char-col can ? 1 Link to comment Share on other sites More sharing options...
elgigante Posted May 28, 2014 Share Posted May 28, 2014 so what is this? and do i run any vac hose from turbo 2 char-col can ? I too neld help with this. Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted May 29, 2014 Share Posted May 29, 2014 Now I'm kinda lost, I have my 87.5 GL with EA82T and an 87.1 RX with EA82T and they both have those same resistors or switches that Angerthis posted in pics.. aren't the pre 87.5 and post 87.5 turbo vaccum lines set up differently?? like older one doesn't use boost selenoid? when I got my RX the wastegate vac line went from wastegate straight to turbo outlet side. most the vac lines on my RX were all switched around and messed up so I thought i'd just copy my GL vacuum.. Could someone help with these vacuum switches..? Haha now im lost with my RX vacuum lines too Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted May 29, 2014 Share Posted May 29, 2014 I need to find my books... haha then I can probably help you Link to comment Share on other sites More sharing options...
angerthis Posted May 29, 2014 Author Share Posted May 29, 2014 my 86.1 RX has the dummy light on the instrument panel with a turbo and it would light up win i exsellerate so on your RX were does the vack lin at char-col can go to? Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted May 29, 2014 Share Posted May 29, 2014 the bigger vac line thats farthest from front of car on vap cannister? mine goes to a T into the rubber intake boot on turbo.. once im out of school today i'll see where the other vac line from that T goes. im pretty sure it goes to one of those sensors/switches that you posted in pics Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted May 30, 2014 Share Posted May 30, 2014 so what is this? and do i run any vac hose from turbo 2 char-col can ? the top sensor in pic goes to a T about 2 inches off of it. one line goes toward cab to the small vac canister behind strut tower, and the other line off of the T goes to the intake. after the throttle body.. theres a spot on intake to put vac line thats the rear passenger side intake runner about half way between injector and throttle body. the bottom sensor connects to to a T on the intake side of the turbo on the rubber boot, like i was saying with the charcoal canister hose.. mine has the 'T' metal piece in the intake boot, its pointing toward front of car when installed. the big hose on the charcoal canister thats closest to the cab of car goes to the T of that sensor if anyone with more experience in EA82T vacuum could help confirm my logic that would be greatly appreciated Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted May 30, 2014 Share Posted May 30, 2014 sorry, i hope that was somewhat clear enough to help out a bit.. Link to comment Share on other sites More sharing options...
angerthis Posted May 30, 2014 Author Share Posted May 30, 2014 ill let you know it is a little confusing but you gave a nuff info i think i can finger it out LOL i hope thanks 4 your time Link to comment Share on other sites More sharing options...
jono Posted May 30, 2014 Share Posted May 30, 2014 (edited) OK, surely the pics of those two solenoids are same as my 85'86 Series 1 turbo. My 85, just before I dismantled, I disconnected, believe now, for I left it to my memory, with top one disconncted, the boost light in dash still worked. So, I think the bottom one is for bost light in dash, and top one must be ECU overboost protection solenoid. Again, from memory, both of these were connected vacuum wise with a T junction nearby and a further junction where one end, yes, went to the cylindrical gadget plastic up on RHD drivers side strut tower to firewall space. Cylinder has two hose ports , labeled 1 and 2. The vac supply for all this and more - vacuum controls in dash - came directly from intake manifold, near RHD brake booster vacuum port with T junction goin' off to the solenoids in ya picture easy Edited May 30, 2014 by jono Link to comment Share on other sites More sharing options...
angerthis Posted June 4, 2014 Author Share Posted June 4, 2014 you make it sound easy i no it should be and it will be after i figure it out new 2 the turbo world Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted June 4, 2014 Share Posted June 4, 2014 More like big mess of vacuum world... Link to comment Share on other sites More sharing options...
