mm88swrt Posted May 26, 2014 Share Posted May 26, 2014 ive got my 87 gl-10 that has a very rough idle. the motor is built.... has pistons, cams, valves, td04 turbo, header and downpipe. anyways, the motor will crank over and run on its own. so to begin, i have great spark to all 4 cylinders. engine timing is correct as well as ditsy timing. plug wires are put on as 1-3-2-4 which is correct. it does not want to rev at all when running. with all the checks i've done it seems to me that the driver side bank is not shooting fuel into the motor. i've pulled spark plugs for each cylinder and the motor continues to run unless the number one plug is pulled. when both 2 + 4 injertors get pulled it doesn't seem to make a difference. when i pull the injector wires one at a time on the driver side (2+4) it does not seem to make a difference. or at least it's minimal. i'm at a lost as what else to say about the condition, so ask what you may. any help is greatly appreciated!!! thank you Link to comment Share on other sites More sharing options...
turbosubarubrat Posted May 26, 2014 Share Posted May 26, 2014 If its rocking back and forth really hard the #2 and #4 injectors are plugged up so fuel cant go in at the right psi or they are on their way out soon. One of my ea81t's had the same problem where one injector went out and it was running on 3 cylinders. Link to comment Share on other sites More sharing options...
BoostedBoxer421 Posted May 26, 2014 Share Posted May 26, 2014 +1^^ first I would think is that drivers side injectors are plugged, wiring bad, or just going out How much boost you pushin?? Injectors aftermarket? They might not be liking the higher than stock boost and are getting worn out from it Link to comment Share on other sites More sharing options...
mm88swrt Posted May 26, 2014 Author Share Posted May 26, 2014 (edited) Ya, im thinkin the injectors might be going out. The weird thing is the motor ran just fine before it was pulled. My boost is always right at about 9psi, which is the least as i can go after everything ive done to the motor. Injectors are stock for now. Im headed out now to test it all out, make sure the injectors are spraying and such. Edited May 26, 2014 by mm88swrt Link to comment Share on other sites More sharing options...
mm88swrt Posted May 27, 2014 Author Share Posted May 27, 2014 Ok figured it out. The #4 follower for the intake broke... which ive never seen before. Compression test was showing zero on #4. Tore it apart and found that. All the fuel is working fine. Great spark and fuel timimg is correct. So just some timing and this monster will be back on the road. After a re torque and an oil change. Ive gotta find out why it will not let me put pictures up, that way i can show it off... it looks pretty wicked and sounds even better! Link to comment Share on other sites More sharing options...
