Suba_GL_87 Posted May 27, 2014 Share Posted May 27, 2014 87 suba gl FI 4wd; When I start it or idling there's pretty low pressure oil pump (0-5psi) also rough idling too. But running to drive city/hwy there's good oil pressure (45psi) I did repair oil pump gasket.. But you think need repair oil pressure sender sensor or oil pump. Heres' video. Thanks Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted May 27, 2014 Author Share Posted May 27, 2014 (edited) . Edited May 27, 2014 by Suba_GL_87 Link to comment Share on other sites More sharing options...
Dee2 Posted May 27, 2014 Share Posted May 27, 2014 low readings at idle are common. Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted May 27, 2014 Author Share Posted May 27, 2014 I dont understand what's you mean a common? It's low psi when idling plus rough. Link to comment Share on other sites More sharing options...
MilesFox Posted May 28, 2014 Share Posted May 28, 2014 next to sero readout is normal during idle. if the engine runs rough, suspect other issues. perhaps the timing is off if you had the belts out Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted May 28, 2014 Author Share Posted May 28, 2014 next to sero readout is normal during idle. if the engine runs rough, suspect other issues. perhaps the timing is off if you had the belts out Actually already installed new timing belt kits & oil pump gasket. You mean camshaft sprocket's tooth off? Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 1, 2014 Author Share Posted June 1, 2014 Yeah, I was test oil pump pressure test was good psi. But I don't know why still rough idle and pretty low rpm before die. I was put adjuster more fuel/mixture on crab/FI for avoid to low rpm... Link to comment Share on other sites More sharing options...
