Phizinza Posted May 29, 2014 Share Posted May 29, 2014 Hi, I'm wanting to put power steering in my Brumby. It will have an EJ with EJ P/S pump. My major question is does the Legacy rack have less travel (turning circle) than the EA82 rack? I know the EA82 racks are very much like the EA81 racks for allowing sharper turning circles but the 2000 model Outback rack is very limited with turning circle.. Thanks, Phiz Link to comment Share on other sites More sharing options...
Gloyale Posted May 30, 2014 Share Posted May 30, 2014 You need an EA81 rack.. I've put EJ and EA82 racks in EA81s......but the problem is when you turn it alters the toe.....since the distance between inner tierod pivots and the A-arm pivots is not equal. Toe it correct for wheels forward.........but then at full lock toe inside wheel goes way to far and toe goes out. Makes for terrible tire wear. Link to comment Share on other sites More sharing options...
Phizinza Posted June 4, 2014 Author Share Posted June 4, 2014 Interesting.. I fail to see how this is an issue unless suspension travel is also factored in..? Link to comment Share on other sites More sharing options...
Gloyale Posted June 7, 2014 Share Posted June 7, 2014 You need a rack that is the same width from inner tierod to tierod as the A-arm pivot to pivot width. If that is correct......all parts of the suspension stay triangulated the same as the suspension travels, and the wheels are turned....... If thoses widths are different......the triangulation changes as you turn the wheel off center. I used a legacy rack in an EA82.....and it worked well....seemingly.......until we started noticing that when you turn the wheels the toe changes....and it scrubbed the tires terribly. 2 Link to comment Share on other sites More sharing options...
Phizinza Posted June 7, 2014 Author Share Posted June 7, 2014 Surely that would only have an effect if the suspension were to travel while turning? I'll need to mock up some suspension and see this Link to comment Share on other sites More sharing options...
Gloyale Posted June 8, 2014 Share Posted June 8, 2014 I said "triangulation" earlier....but let me be more accurate....it's actually about keeping parallelograms. You want the tierod link and the control arm to maintain a perfect parallelogram. Both in the horizontal and vertical planes......No matter how you turn or how the suspension travels. A parallelogram with sides of a given length can have any range of angles between 1 and 179. But this parallelogram must have 2 sets of EQUAL sides or else it's not a parralellogram. this means some distances must be equal. rack end to end = A-arm pivot width. Rack postion above a-arm pivot = height from lower balljoint to outer tierod end@knuckle Rack position forward of the axle centerline = horizontal distance axle centerline to outer tierod@knuckle Any of these being off will make trapezoids rather than paralellograms as things move. The angles of a trapezoid cannot be changed without affecting the length (distance) of the sides. This is why the toe of the wheels relative to each other will change when you use a rack wider than the pivots. 1 Link to comment Share on other sites More sharing options...
czny Posted June 8, 2014 Share Posted June 8, 2014 Not MacPherson but you'll get the idea of arm & steering geometry: https://www.google.com/search?q=MacPherson+suspension+with+rack+%26+pinion+steering+animated&client=firefox-a&hs=gfX&rls=org.mozilla:en-US:official&channel=np&tbm=isch&imgil=SKXi2HtTHPHM3M%253A%253Bhttps%253A%252F%252Fencrypted-tbn2.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcQb-nMBu-qxkm62IVqOoWOQG-V7pHFQVJigfitNDWMjljDJhzH5%253B407%253B291%253Bbt34G0QfkUBCmM%253Bhttp%25253A%25252F%25252Fwww.dwightsautorepair.com%25252Fsteering-suspension.html&source=iu&usg=__6sRcgab577Q6Nli53A45pKpurk8%3D&sa=X&ei=nPiTU_X9KIPeoATty4DoBw&ved=0CCgQ9QEwAQ&biw=1440&bih=707#facrc=_&imgdii=_&imgrc=av0hNKNvFP39WM%253A%3B5ArEvs-OSfGnyM%3Bhttp%253A%252F%252Fwww.technicopedia.com%252Ffund%252Fackerman.gif%3Bhttp%253A%252F%252Fwww.technicopedia.com%252Ffundamentals.html%3B400%3B225 Link to comment Share on other sites More sharing options...
Phizinza Posted June 9, 2014 Author Share Posted June 9, 2014 I get it now. I was ignoring the fact that the steering works on the horizontal plane and only considering the effects of it on the vertical plane.. Thanks Link to comment Share on other sites More sharing options...
Gloyale Posted June 10, 2014 Share Posted June 10, 2014 I didn't get it either until I tried to put a Subaru rack into my Trooperu project.........first attmepts yeilded terrible alignment....had to find it out. Link to comment Share on other sites More sharing options...
86hatchback Posted June 12, 2014 Share Posted June 12, 2014 So if your inner tie rods pull from the center of the rack like a dodge intrepid, instead of the ends like a Subaru, would you still get negative results or would that make toe change better? Link to comment Share on other sites More sharing options...
Uberoo Posted June 13, 2014 Share Posted June 13, 2014 I have no idea how good steering geometry is even achieved with a center steer type rack.The inner tie rods mount near the center and are far away from the control arm mounts.When the wheel is turned the inner tie rods slide from one end to another,but the displacement on each side is the same.It might work only in the horizontal plane but throw in some movement on the vertical plane and it seems like its a recipe for bump steer. A conventional rack that mounts the inner tie rod ends at the end of the rack is sized so with the steering centered the tie rods are at the pivot point of the control arms.So when the wheel is turned each end move the same distance towards or away from center making each wheel behave like the ends of a parallelogram so the wheels are roughly parallel. In real life throw the various angles of the tie rods to the control arms and the spindles themselves a little bit of difference between inside and outside tire angle is achieved which is good for low speed turning but bad for high speed stability. If the wheels have too much difference between them they scrub at low speed and are very sketchy to drive at high speed because a little movement at one tire corresponds to a large angle at the other tire. On the other hand if the wheels are always parallel then they scrub at at low speed but provide better high speed stability(15 MPH +).If you google "ackerman angle" it will probably explain it better than I can. Link to comment Share on other sites More sharing options...
Phizinza Posted June 17, 2015 Author Share Posted June 17, 2015 Bringing this back up from the dead as I've found all these three racks (RHD) are the same length, it's only the inner tie rod ends (rack ends) that are longer. So I see no issue with geometry running any of the other racks with the EA81 inner tie rod ends bolted to it. Link to comment Share on other sites More sharing options...
86hatchback Posted June 18, 2015 Share Posted June 18, 2015 Only hitch would be the inner tie rod on a ea81 has a female connection ea82 ej has a male connection. High grad all thread maybe? Link to comment Share on other sites More sharing options...
Phizinza Posted June 19, 2015 Author Share Posted June 19, 2015 Yes, found that out. EA82 rack is female m14, EA81 tie rods are female m16. I'm going to make a piece of threaded rod with both threads to adapt. Link to comment Share on other sites More sharing options...
comatosellama Posted January 26, 2016 Share Posted January 26, 2016 Yes, found that out. EA82 rack is female m14, EA81 tie rods are female m16. I'm going to make a piece of threaded rod with both threads to adapt. Any update on that? Link to comment Share on other sites More sharing options...
Phizinza Posted January 26, 2016 Author Share Posted January 26, 2016 (edited) Made the adapters. They fit. The racks are the same length. The ea82 rack fits my Brumby no worries. Angles all look the same. Still need to put the crossmember with that rack in the car. Edited January 26, 2016 by Phizinza Link to comment Share on other sites More sharing options...
Gloyale Posted January 28, 2016 Share Posted January 28, 2016 Take the boots off and compare. They are different. Tell me how your tires are wearing after a 10,000 Kilometers. Link to comment Share on other sites More sharing options...
comatosellama Posted January 28, 2016 Share Posted January 28, 2016 Take the boots off and compare. They are different. Tell me how your tires are wearing after a 10,000 Kilometers. Is it possible that could be from the inner tie rod ends being longer, and needing longer boots to fit? I'm hoping this would actually work out, throwing in the PS rack from an ej while doing an ej swap would be a very nice addition to my brat Link to comment Share on other sites More sharing options...
Phizinza Posted January 28, 2016 Author Share Posted January 28, 2016 My ea82 rack with ea81 rack ends is the same overall width as an ea81 rack. Link to comment Share on other sites More sharing options...
