Tman1058 Posted June 1, 2014 Share Posted June 1, 2014 I'm about to lift my '87 gl 2" but I'm going to need to extend the steering shaft. I've read somewhere that you don't have to do any welding if you combine power steering and non power steering linkage, which is what I'd like to do, my car is power steering and I have a non ps parts car, I'd like to know which sections of which linkage I need to use. Thanks in advance, Tom Link to comment Share on other sites More sharing options...
Skylar Posted June 1, 2014 Share Posted June 1, 2014 You don't need a steering extension with a 2". You'll do Just fine without. If anything, go snag one from an Obs or an Outback if you want the steering extension. They're slightly longer than a stock ea82 coupler. 1 Link to comment Share on other sites More sharing options...
Tman1058 Posted June 1, 2014 Author Share Posted June 1, 2014 I've heard that a 2" is hit and miss if you need one or not, did I hear wrong? Link to comment Share on other sites More sharing options...
Skylar Posted June 2, 2014 Share Posted June 2, 2014 9/10 it's a hit. I personally haven't had to extend the steering coupler on a 2". Grab an outback steering coupler just to be safe & throw your lift on & see what happens. Link to comment Share on other sites More sharing options...
bratman18 Posted June 2, 2014 Share Posted June 2, 2014 You'll only need a longer steering coupler if you drop the front crossmember as well. Usually with a 2" lift you only drop the struts down. But if you do drop the front crossmember, then you'll need the steering coupler lengthened the same amount as that is dropped. Link to comment Share on other sites More sharing options...
Gloyale Posted June 2, 2014 Share Posted June 2, 2014 Actually if you drop it you need a coupler that is longer but not by the same amount. It will actually be a bit less. think of it as a right triangle......where the coupler is the hypotinus of the triangle. we will call that "C" the height difference of the rack end, and the column end is "B" and the horizontal length is "A" So if you drop the crossmember 2" you need a coupler that is A squared + (B+2") squared = C squared 2 Link to comment Share on other sites More sharing options...
