TallonX Posted June 2, 2014 Share Posted June 2, 2014 From my understanding accord springs with 2wd struts will yield 4" of lift for the rear probably more. Can I get confirmation on this number? Link to comment Share on other sites More sharing options...
Uberoo Posted June 2, 2014 Share Posted June 2, 2014 3.5-4" yes, but you will need to drop the diff. Link to comment Share on other sites More sharing options...
Gloyale Posted June 2, 2014 Share Posted June 2, 2014 You will be maxed at full extension all the time. Beat the crap out of your kidneys, handle like poop, and probably blow the lower perch off if you ever do get any uptravel. If you want to get an idea of the height.....just jack up the car til the rear wheels barely touch.....this is were it will ride all the time with those springs. He won't need to drop the diff.....the shock will still be the same length with the same mounting points. No travel or clearance gained just super stiff and maxed out extended. If you want to use those springs, cut 3/4~ 1 coil off to keep it reasonable. Link to comment Share on other sites More sharing options...
TallonX Posted June 4, 2014 Author Share Posted June 4, 2014 Thanks for the info Seriously tho if that's how it'll sit, that's pushing closer to 8" Link to comment Share on other sites More sharing options...
AKghandi Posted June 4, 2014 Share Posted June 4, 2014 (edited) id go with the 4 runner strut upgrade also. it will be about 2" lift and stiff. i keep alot of crap in my car and im sitting on virtually no suspension with the stock coils with the 4 runner struts. im going to get the honda coils soon and after i remove the rear strut lift it should be about perfect. Edited June 4, 2014 by AKghandi Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted June 5, 2014 Share Posted June 5, 2014 (edited) ... Beat the crap out of your kidneys, handle like poop, and probably blow the lower perch off if you ever do get any uptravel... Very Respectfully, I have to Disagree with that Statement. Have you ever tried that setup? I Run my Subaru "BumbleBeast" with Honda Accord front coil springs on the Rear, with Awesome Results, since many, many years ago; as you can read, Here: ~► http://www.ultimatesubaru.org/forum/topic/106807-improved-shock-absorbers-and-spring-coils-on-loyales/ At first, I used them with the Stock Shock Absorbers, then along the 4Runner Shock absorbers and I've put many thousands of Miles on mixed driving styles with them, without a single problem so far; in fact, the Car's Handling unloaded & loaded becomes Amazing. Let me Share here, another Member's opinion on the same Subject, he installed those accord coil springs on his wagon: This measurement might be a little off. But I'm somewhere close to 29.5-30 at the top of the rear. If my original was 28.25 these springs rock! I've noticed a significant change in the way my car handles and rides. I'll try to describe it. You know when you hit a bump in the road or pothole? how your car bounces up, then comes down pretty hard, then bounces a little more? These springs help minimize that. I noticed when I hit a bump the extra coils and more tightly wrapped spring help to smooth out the transition from hitting the bump. The car doesn't come down as hard as it used to and cornering is a bit more "sporty". Overall sweet little mod you can do in not too much time. Thanks to Jes for the info and Marcus for the idea! Kind Regards. Edited June 5, 2014 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
