Uberoo Posted June 6, 2014 Share Posted June 6, 2014 Of the people that still make adapter plates, who makes the plates with the upper holes siamezed so a single offset bolt goes through the adapter plate to both engine and transmission?I'm looking to remake the steel plate I made along time ago.Tired of having to drill out the holes on the engine.So I'm looking for some of the offset bolts... Link to comment Share on other sites More sharing options...
Scooner Posted June 7, 2014 Share Posted June 7, 2014 Just weld some together bro man, that's all they are. Link to comment Share on other sites More sharing options...
Uberoo Posted June 7, 2014 Author Share Posted June 7, 2014 I thought they were shaved down alittle then welded? Link to comment Share on other sites More sharing options...
Scooner Posted June 7, 2014 Share Posted June 7, 2014 When i did mine i just welded two bolts together and it worked great. Even if they were shaved, you could grind them a little then weld them, just test fit them suckers and you shouldn't have a problem. Link to comment Share on other sites More sharing options...
Uberoo Posted June 9, 2014 Author Share Posted June 9, 2014 yea,I was thinking of sliding the engine and transmission together,and putting some bolts through each one and welding them together where they meet.Then modify the steel adapter plate so they fit. Link to comment Share on other sites More sharing options...
Uberoo Posted June 9, 2014 Author Share Posted June 9, 2014 Does anyone still make an aluminum adapter plate with the top holes milled out?I got to thinking how heavy my steel adapter plate is,and everything could always weigh a little less... Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted June 9, 2014 Share Posted June 9, 2014 I can mill out mine if that's what you want, I run smaller diameter studs into the top engine side so no need to drill out threads Link to comment Share on other sites More sharing options...
Gloyale Posted June 10, 2014 Share Posted June 10, 2014 Does anyone still make an aluminum adapter plate with the top holes milled out?I got to thinking how heavy my steel adapter plate is,and everything could always weigh a little less... 4 or 5 threads in steel is plenty.... in aluminium it's not enough. That's why the factory threads in the EJ block are nearly an inch deep. you don't want just a couple threads of aluminum holding your engine and trans toghether. If I were to run an aluminuim plate, it would be with siamesed bolts.....you're on the right track Uberoo. I would not trust on;y 1/2" of M8 threads. Link to comment Share on other sites More sharing options...
4play Posted June 27, 2014 Share Posted June 27, 2014 I have a guestion about adaptor plates also.the one I saw a pitchure of had 2 ear things on the top of it. what are thay for? Link to comment Share on other sites More sharing options...
Scooner Posted June 27, 2014 Share Posted June 27, 2014 That's for making a pitch stopper my friend! Link to comment Share on other sites More sharing options...
Crazyeights Posted June 27, 2014 Share Posted June 27, 2014 I can mill out mine if that's what you want, I run smaller diameter studs into the top engine side so no need to drill out threads Scott, your adapter has been working for me like that for years. Thanks... Jeff Link to comment Share on other sites More sharing options...
4play Posted June 28, 2014 Share Posted June 28, 2014 pitch stoper, ok so can some one post a pitcher of the top to bolts, and how thick of a plate do you use for the adaptor . Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted June 28, 2014 Share Posted June 28, 2014 Scott, your adapter has been working for me like that for years. Thanks... Jeff thats a great report thanks pitch stoper, ok so can some one post a pitcher of the top to bolts, and how thick of a plate do you use for the adaptor . the adapter is the stock bracket from a EA82 trans or 1/8 thick angle Iron would work Link to comment Share on other sites More sharing options...
Crazyeights Posted June 28, 2014 Share Posted June 28, 2014 thats a great report thanks the adapter is the stock bracket from a EA82 trans or 1/8 thick angle Iron would work The EA81 style pitch stopper bracket works great with Scott's EJ adapter also. Link to comment Share on other sites More sharing options...
4play Posted June 28, 2014 Share Posted June 28, 2014 hope you dont think I am highjackung this thred,but I just bolted a pitch stopper bracket from a legacy trans to the dr I have in the garoge. hope to get the adaptor plate cut out ot 1/4" plate this weekend, just need to see a pitchure of the top two bolts, getting closer to having dualrange. Link to comment Share on other sites More sharing options...
Gloyale Posted June 28, 2014 Share Posted June 28, 2014 hope you dont think I am highjackung this thred,but I just bolted a pitch stopper bracket from a legacy trans to the dr I have in the garoge. +1 No need for any tabs on adapter plate. EJ bracket bolts to EA 5spd. I suppose with a 4spd maybe woudl be needed. 1 Link to comment Share on other sites More sharing options...
