dp213 Posted June 7, 2014 Share Posted June 7, 2014 My 99 legacy has a bad 2.2 in it. Will a 2.2 from an earlier model work to replace it? Thanks Link to comment Share on other sites More sharing options...
Prwa101 Posted June 7, 2014 Share Posted June 7, 2014 please exsplain what you mean by a "bad 2.2"? could be fixable, or parshily salvagable. Link to comment Share on other sites More sharing options...
dp213 Posted June 7, 2014 Author Share Posted June 7, 2014 It has 300,000 miles on it. A bad head gasket, rings are bad, water pump siezed and that's just the beginning. Link to comment Share on other sites More sharing options...
Rooster2 Posted June 7, 2014 Share Posted June 7, 2014 It has 300,000 miles on it. A bad head gasket, rings are bad, water pump siezed and that's just the beginning. Yep, that sounds bad enough. Others know a lot more then me. Yes, I have read that you can install a 2.2 from earlier years..........prolly need the intake manifold from your old motor, and may need to change the exhaust manifold. Possibly some other issues to interface OBD1 to OBD2. Link to comment Share on other sites More sharing options...
johnceggleston Posted June 7, 2014 Share Posted June 7, 2014 the 99 ej22 can not be replaced with an earlier one. you need either a 99 - 00 ej22, legacy or impreza, or a 00 - 03/4 ej25. there are some tricks to making it work, bolt on your intake, and cam / crank sprockets. however, you could use an earlier ej22 block and bolt on your heads, intake, and cam / crank sprockets. that would work. Link to comment Share on other sites More sharing options...
Prwa101 Posted June 7, 2014 Share Posted June 7, 2014 (edited) Good informations haha.. ^ what he said Edited June 7, 2014 by Prwa101 Link to comment Share on other sites More sharing options...
idosubaru Posted June 8, 2014 Share Posted June 8, 2014 99 legacy EJ22 99-01 impreza EJ22 the only way to use an older EJ22 is to bolt your existing heads to an older EJ22 block. at 300,000 miles, i wouldn't do that without replacing the valve stem seals and grinding the valve. a machine shop can easily do that. Link to comment Share on other sites More sharing options...
dp213 Posted June 9, 2014 Author Share Posted June 9, 2014 So with a manufacturing date of 9/98 does that meen it is a non interference 2.2 motor. Link to comment Share on other sites More sharing options...
Suzam Posted June 9, 2014 Share Posted June 9, 2014 MY97 2.2 and later are all interference. Link to comment Share on other sites More sharing options...
idosubaru Posted June 9, 2014 Share Posted June 9, 2014 So with a manufacturing date of 9/98 does that meen it is a non interference 2.2 motor. all 1997 and up Subaru EJ engines are interference. that's a 1999 Phase II, definitely inteference. Link to comment Share on other sites More sharing options...
dp213 Posted June 18, 2014 Author Share Posted June 18, 2014 Will a 2.2 from a car with an automic work in my car with a 5 speed Link to comment Share on other sites More sharing options...
idosubaru Posted June 18, 2014 Share Posted June 18, 2014 (edited) Will a 2.2 from a car with an automic work in my car with a 5 speed yes it will, transmission doesn't matter. you can even swap ECU's between auto and manual Subaru's, doesn't matter. things like year, make, model, and EGR are what matters. Edited June 18, 2014 by grossgary Link to comment Share on other sites More sharing options...
dp213 Posted June 18, 2014 Author Share Posted June 18, 2014 The motor is out of a 99 outback sport and going into a 99 legacy l Link to comment Share on other sites More sharing options...
idosubaru Posted June 19, 2014 Share Posted June 19, 2014 The motor is out of a 99 outback sport and going into a 99 legacy l if the 99 Legacy is originally an EJ22 (which an L model would be if that's what the l stands for) - they are the same. if on the other hand, the 99 legacy originally came with EJ25 - and was previously swapped with an EJ22 - then the 99 Outback Sport engine would not work. Because a 99 EJ25 legacy is Phase I so someone would have had to swap a Phase I 98 or earlier EJ22. but 99 EJ22 legacy's are Phase II. Link to comment Share on other sites More sharing options...
dp213 Posted June 19, 2014 Author Share Posted June 19, 2014 I don't have the intake from my car. Will the intake on the motor from the outback sport work Link to comment Share on other sites More sharing options...
idosubaru Posted June 19, 2014 Share Posted June 19, 2014 Yes. As long as your legacy was ORIGINALLY an EJ22 engine. Is it a 1999 Legacy L (if not - what model is it?). The Wizard of Oz Subaru - it has not intake manifold. Link to comment Share on other sites More sharing options...
dp213 Posted June 19, 2014 Author Share Posted June 19, 2014 It is a L Link to comment Share on other sites More sharing options...
