Throw our bearing question.
Support the actual bearing on it's outer edges between the jaws of a vice find an appropriate sized socket that fits the throwout bearing holder and then tap the holder out of the bearing, The socket will transfer all the force evenly so as to not damage the bearing holder.
Obviously a socket that fits inside of the new bearing will drive out the holder from the bearing and if you do not want to damage the socket put a piece of timber on top of the socket and hit that with a hammer.
If you do not have a vice then you can support the outer race of the bearing on a couple of pieces of timber.
