Gwywnc Posted June 12, 2014 Share Posted June 12, 2014 So I'm making my gl into a manual trans and I had to remove the whole steering wheel to put the petal assembly in anyways I was looking at this and was wondering if I should replace it? The donor car don't have this it's just the "u-joint" should I take the one from the donor car or will this be fine? Thanks Link to comment Share on other sites More sharing options...
Dj7291993 Posted June 12, 2014 Share Posted June 12, 2014 (edited) It would be a good idea. It's called a rag joint. Should be able to pick one up at the parts house. I don't think they're too expensive. Should tighten up some of the play in your steering. Better to change it now, while you have it out, then to put it back in, and have to pull it back out later. If it does tear, you can pretend like you're driving through a movie. Edited June 13, 2014 by Dj7291993 Link to comment Share on other sites More sharing options...
skishop69 Posted June 13, 2014 Share Posted June 13, 2014 +1 Change it. Ever driven a car that went from steering to little or none? No bueno! lol Link to comment Share on other sites More sharing options...
Dania02525 Posted June 13, 2014 Share Posted June 13, 2014 I changed mine with advice from someone on here to a nice red poly one from a vw bug. I think it was $8 on Amazon :-) Link to comment Share on other sites More sharing options...
Uberoo Posted June 14, 2014 Share Posted June 14, 2014 Just bolt the two halves together with some washers to take up the slack.screw that rubber rag joint. Link to comment Share on other sites More sharing options...
Dj7291993 Posted June 14, 2014 Share Posted June 14, 2014 Just bolt the two halves together with some washers to take up the slack.screw that rubber rag joint. That works too. Just for the OP's information, the rag joint is used to give it a flex point, possibly as an impact cushion. I'm not against eliminating parts that you feel are unnecessary, but it's always good to know why it's there in the first place before you decide it's not needed. Link to comment Share on other sites More sharing options...
