ea82 wheen should I be boosting
Never drove a ea82 until I purchased one.
I dont know how they run when running good.
When driving on the highway when I get to about 4k the car feels like boost kicked in. Is this right?
Also sometimes the green turbo light will stay on until I punch the throttle. I thought it only goes on when im boosting
Edited by elgigante
  • Like 1
is this the same vehicle you have lots of posts on ??
My 85 EA82T boost light came on about 2500rpm, but only when conditions were right - a vacuum/boost gauge really helps to drive a turbo by.
Should feel the power (be careful :) ) about 2500 up to about 4000 on most EA82T. Only when something was wrong with my blow of valve install did I only feel power starting at 4000rpm - hated it, nasty slap in the back and 1500rpm too late, snails were sniggering at me :(
for the 87.5 spider turbo .....
the T off the device (mine has same red part number label)goes to the wastegate diaphragm, so this is the bit that is off to right angles where the other two go through device in a straight line OK ??
The straight line on device all on its own goes or rather comes from the turbo alloy housing just in front where outlet hose for compressed air comes out of turbo, It has a small inline valve for either restriction or flow direction.
The other end, closer to the T off is like a vent outlet and ends up witha T fitting and goes to intake boot, the other end of that T ties into a metal tube coming off inlet manifold tree of tubes, comes around corner and its end points right at turbo
yeah, your picture - lets call each of three pipes on the solenoid a port?
the hose still fitted in pic?  - the empty end goes where this next few lines takes it-
"The straight line "port" on device all on its own goes or rather comes from the
or flow direction".
Fit that and you have two hoses to find and fit at the other end. The port coming off at right angels to the other two ports, one you have just found a connectuion for abovee??
Sorry, just read that - needs rewriting ...
At the other end where you see two ports to the solenoid, one is straight out, the other goes off at right angels, 90 degrees - OK, got it ?
The straight out is really a vent off or bleed off from the solenoid so this connects to the intake rubber boot after the afm, somewhere near where the PVC hose fits up. It also has a T in this line, close to where you hook it into the rubber intake boot. Maybe for this stage forget the T in line and just connect it to the boot ?
Edited by jono
