jonas Posted June 14, 2014 Share Posted June 14, 2014 About 2k miles on new pads, ball joints, tie ends. No probs. till now Just had alignment done. Was driving on the freeway when it just started pulling HARD to the left. Managed to get pulled over safely. Waited a few minutes, started driving and it was fine. After about 5 minutes it did it again. Inspected front end today and nothing seems amiss. Brakes and rotors look good, nothing is loose, drained a little brake fluid and it's clean. Not sure what to make of this. Link to comment Share on other sites More sharing options...
jonas Posted June 14, 2014 Author Share Posted June 14, 2014 I suspect my calipers not adjusting correctly and not leaving enough gap between the rotor and pads to keep cool. Link to comment Share on other sites More sharing options...
l75eya Posted June 14, 2014 Share Posted June 14, 2014 I just had this happen to my GL but I was fortunate enough to know what it was. New driver's side axle and problem is gone. I destroyed my already on the way out axle while offroading. Had a very hairy 100 mile drive home with it randomly pulling very hard to the right.I think to see if it's your axle, when it's pulling to the left try giving the car a lot of throttle. When the axle is bad, the extra torque from accelerating hard will straighten it out, and when you let off it will all loosen up and start pulling again. That's what mine did anyway. Link to comment Share on other sites More sharing options...
jonas Posted June 14, 2014 Author Share Posted June 14, 2014 Thanks, I've been suspicious of that axle for awhile. Plenty experience with bad axles but never had that happen. Link to comment Share on other sites More sharing options...
l75eya Posted June 14, 2014 Share Posted June 14, 2014 Had that happen to both my fronts, though when the pass side went I just had steering wobble, not a pull. Link to comment Share on other sites More sharing options...
Tsuru Posted June 18, 2014 Share Posted June 18, 2014 it's your steering - Its "Rack and Opinionated"... (sorry, that was bad) I'm with I75eya, sounds like an axle. if it's a brake you would be smelling it fairly early on. (I would think) Respectfully, Timothy Link to comment Share on other sites More sharing options...
