gsac132 Posted June 15, 2014 Share Posted June 15, 2014 My 99 subaru forester has a air bag light on is this a stealership trip or is there a way to diagnosis it Link to comment Share on other sites More sharing options...
rverdoold Posted June 15, 2014 Share Posted June 15, 2014 you could get a 12 dollar OBD usb-cable (k-line) from internet and use FreeSSM to check the computer. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 15, 2014 Share Posted June 15, 2014 There is a small black connector under the dash and one of the pins can be jumped to ground to make the Airbag module flash the codes via the airbag light on the dash. I don't remember the exact pin off hand but can look it up later. Most common reason for an airbag light is a bad clock spring behind the steering wheel. This can also cause the horn and cruise control to not work. Link to comment Share on other sites More sharing options...
