idosubaru Posted June 16, 2014 Share Posted June 16, 2014 My daily driver 2002 H6 has the timing chains removed and cam/crank indexing is suspect.Crank is at 2pm and moving it either direction it runs into something.I can't move it from 2pm to 12 noon, it stops about a tooth or so short - presumably touching valves?Cams are all lined up with marks at 12 noon. How do i move the crank or cam while making sure I don't have a loaded cam throw a valve into a piston? Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 16, 2014 Share Posted June 16, 2014 Are you positive you have the correct mark on the crank? A loaded cam means its holding the valves open. The spring pressure of the valve spring is the load. Unloading the cam is when the valves close. If you need to turn the crank counter clockwise, turn the cams counter clockwise slowly with a wrench or breaker bar so you can control the rate they turn. Set the crank, then slowly turn the cams back. Link to comment Share on other sites More sharing options...
idosubaru Posted June 17, 2014 Author Share Posted June 17, 2014 i unloaded all cams and had the same issue. i thought i was doing this right. seems a mouse filled one of the cylinders with rice. what a debacle. blew it out with cimpressed air. ill leak down test it and im going with it. maybe put some oil in cylinders in case that softens up any rice. may test some rice in a cup see what it does. LOL Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 17, 2014 Share Posted June 17, 2014 Well that's a new one! I guess the worst that could happen is a piece could get stuck under an exhaust valve and hang it open. Maybe some PB would melt it? Link to comment Share on other sites More sharing options...
idosubaru Posted June 17, 2014 Author Share Posted June 17, 2014 Well that's a new one seriously. i noticed it because rice came out of the spark plug hole. why can't those #(*)!(*$! drink the antifreeze! I guess the worst that could happen is a piece could get stuck under an exhaust valve and hang it open. i'm slightly concerned - there was a significant "notch" hanging up the crank. even after freeing it up, it still had a noticeable "lump" in the exact same spot while turning the crank. i could turn it back and forth over this one spot and feel it. kind of like in a Subaru engine that's sat for a long time and the rings are bound/rusted and stuck in the cylinder. maybe they peed in there and rusted up the cylinder wall too. LOL this engine has run perfect with zero issues for the past 100k and has 220k on it, so there's absolutely no question about it's condition. Maybe some PB would melt it? that's what i wanted to do - but wouldn't that wash the cylinders? Link to comment Share on other sites More sharing options...
lmdew Posted June 17, 2014 Share Posted June 17, 2014 A few years ago I had picked up a 2.2 from a fellow. I pressure washed it and then it sat for a month. I had the same issue, the crank was hitting something. I use the borescope at work and looked in the cylinders. Rust had built up on the wall stopping the piston. I soaked it in trans fluid for a few days and then slowly worked it back and forth until it rotated freely. Never had an issue with the engine after that. Good luck. 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 17, 2014 Share Posted June 17, 2014 PB Blaster is unlikely to affect rice. (test ii with some rice from the kitchen?) anything I can think of to 'dissolve' rice is too risky for the metals. (Hydrogen peroxide from the beauty shop, liquid Plumber, etc.) borescope is a good idea. Link to comment Share on other sites More sharing options...
johnceggleston Posted June 17, 2014 Share Posted June 17, 2014 i think the rice will ''cook off'' once you get it running. but the challenge is to get the alignment right with the rice in the way. may be a vacuum cleaner while you open and close the valves? is it only one cylinder? find a way to open the valves for that one cylinder while leaving the others alone. Link to comment Share on other sites More sharing options...
idosubaru Posted June 17, 2014 Author Share Posted June 17, 2014 I blew it out with compressed air, rice shot out of the spark plug hole. Then I propped all the exhaust valves open while blowing air directly into the cylinder via a leak down gauge adapter. The engine still hung and still has a "lump" spot in it when turned over by hand. I presume it's some kind of build up or surface rust like lmdew mentioned. I'll be putting some PB Blaster into the cylinder to help break up the rust. Then rotate the engine a few times and add some oil before buttoning it all up. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 17, 2014 Share Posted June 17, 2014 PB won't wash the cylinders down. It's still oil, though not ideal. But it will also help loosen and remove any rust. I recently helped a friend of mine get an Acura running that had sat in a field for about 6 months. Battery was dead so we had to jump it. We had spark and fuel but not enough compression to get it to fire. Loaded up the cylinders with PB (it was the only oil I had) and let it sit for an hour or so. Put the plugs back in it and it fired on the second stoke. Link to comment Share on other sites More sharing options...
idosubaru Posted June 18, 2014 Author Share Posted June 18, 2014 FT and Imdew - worked like a charm. 1. mouse trap set next to the engine, LOL 2. PB Blaster and within seconds and 2 or so revolutions the "lump" was gone. Link to comment Share on other sites More sharing options...
