lvsarge Posted August 31, 2015 Author Share Posted August 31, 2015 Hey bud, sorry for not getting back to you. I forgot to sign in and reply. I got the axle from rock auto. 1 Link to comment Share on other sites More sharing options...
lvsarge Posted August 31, 2015 Author Share Posted August 31, 2015 Same deal as last year. Too hot in the garage to do any work. I did manage to hit the sander for about 30 minutes. Dash board is starting to look better. More pics when I actually do some real work though 1 Link to comment Share on other sites More sharing options...
Kevint143 Posted August 31, 2015 Share Posted August 31, 2015 Did you get that yellow one from a kid in Vegas? I some what am social media friends with him if you did Link to comment Share on other sites More sharing options...
lvsarge Posted August 31, 2015 Author Share Posted August 31, 2015 I got it from a guy in Vegas, yeah. I wouldn't call him a kid though? He said HE bought it from a kid though. Previous owner only had it for a year. It sat in his garage mostly. I did a comp test on it before I bought it and could see why. Has one bad cylinder and another on the way out. Link to comment Share on other sites More sharing options...
Kevint143 Posted August 31, 2015 Share Posted August 31, 2015 Ok then I know the kid that owned it before. He was about 16/17 and it was his first car. Needed more work than he could give it. Link to comment Share on other sites More sharing options...
lvsarge Posted August 31, 2015 Author Share Posted August 31, 2015 Yeah same with the next owner. He didn't know where to start. Said it ran when he first bought it but then it just sat for a year. Got any info as to what the kid had to do? I mean, body wise this is an immaculate car. It even has all of the A/C bits, too. I got it for pretty darn cheap so I don't mind getting my hands dirty on another truck, but any head's up on what to expect would be great. Thanks! Link to comment Share on other sites More sharing options...
Kevint143 Posted August 31, 2015 Share Posted August 31, 2015 Just sent him a FB message asking what he did and what it needed things I remember off hand is he put a couple new axles on and put a weber on. Link to comment Share on other sites More sharing options...
lvsarge Posted September 1, 2015 Author Share Posted September 1, 2015 Hmm. Still has the stock hitachi. But I'm all ears anyhow Thanks dude. Link to comment Share on other sites More sharing options...
bratbro Posted September 3, 2015 Share Posted September 3, 2015 (edited) On 2/5/2015 at 6:25 PM, lvsarge said: Big huge monster thanks and shout out to superpoo93 (aka Noel) who swung by with his dewalt electro-impact that made short work of that stubborn axle nut. Now, I can get back to work. Thanks again, sir! Was it a corded impact driver? I've soaked the castle nut for 4 days in pb and it still won't budge. Edited September 3, 2015 by bratbro Link to comment Share on other sites More sharing options...
superpoo93 Posted September 3, 2015 Share Posted September 3, 2015 On 1/30/2015 at 12:59 AM, superpoo93 said: Sarge, the offer still stands to use the 1/2 impact wrench (345-ft lbs). and I have a regular 1/2 36mm socket. and a 32mm socket for those aftermarket nuts. I had an issue just like yours and the impact from my work, did the job. I have no problem bringing over, just let me know. I'm free Friday after 5;00pm. and Sun early before the SuperBowl. For you Bratbro* Link to comment Share on other sites More sharing options...
bratbro Posted September 3, 2015 Share Posted September 3, 2015 On 9/3/2015 at 11:16 PM, superpoo93 said: For you Bratbro* Thanks! Looks like I'm getting a new tool then. 1 Link to comment Share on other sites More sharing options...
lvsarge Posted September 6, 2015 Author Share Posted September 6, 2015 Yeah. Much easier to get than the 3/4 breaker bar (which works great) that I was using. Link to comment Share on other sites More sharing options...
lvsarge Posted October 18, 2015 Author Share Posted October 18, 2015 Hey guys. I'm back. So, I've made some progress, but I'm having to step back a bit. I'm having a problem with the clutch. I got the engine to turn over and run, and the clutch pedal was very loose. So I figured it was some adjustment in the cable. I tightened the cable a bit in increments, and the pedal is very loose, like I don't feel any resistance. I operate the fork by hand and the fork is hooked to the springs inside and resets itself, but I don't think the bearing is catching the pressure plate. I had to buy a new one because my old one got caught on the transmission shaft and bent one of the fins. I'm wondering if I bought the wrong sized pressure plate. Any other reason I wouldn't be feeling any resistance in the pedal? Also, any easy way to get the trans out of the way to inspect it? I've got it unbolted, and supported on a jack right now. I'm about to pull the crossmember and just get it on the ground to inspect everything. Link to comment Share on other sites More sharing options...
lvsarge Posted October 18, 2015 Author Share Posted October 18, 2015 I should also add that I can't go into gear with the engine running, so the clutch is not engaging. Link to comment Share on other sites More sharing options...
lvsarge Posted October 18, 2015 Author Share Posted October 18, 2015 But it's not all bad... Seats are in. Yeah, they're ratty. But they're original and not the GL wagon velour style. I'll fix them. Some day.... Also fabbed in the stereo console area. Looks pretty good. As it sits now. Daddy's little helper: 1 Link to comment Share on other sites More sharing options...
lvsarge Posted November 16, 2015 Author Share Posted November 16, 2015 (edited) Hey guys. Another update here. While I continue to struggle with my clutch not engaging (thread here: http://www.ultimatesubaru.org/forum/topic/156414-ea71-clutch-problem/?do=findComment&comment=1308409 ), I managed to finish my dash. Now, the dash did not come out 100% flawless, like I had hoped, but it is about 92% better than it was before. Plus it looks fresh and new(ish). I am pleased with the results. I'd be interested in hearing your thoughts. No pics of it installed yet, as it's still hanging out on my work stand. But here ya go: Took about 5 passes of filler and sanding to get it to this point: I was trying to retain the factory speaker holes, and drilling them out, but it ended up just tearing out my filler. So I filled in the factory speaker holes, as I am not using that speaker or location anyhow: So a couple more passes of filler, and I started the texture process.. Then primer and top coat. Adding some shiny bits: Tonight I'm tackling the clutch again. Hopefully I'll have some good news. Edited November 16, 2015 by lvsarge 3 Link to comment Share on other sites More sharing options...
superpoo93 Posted November 16, 2015 Share Posted November 16, 2015 Sarge, the dash looks amazing!! Great work Link to comment Share on other sites More sharing options...
lvsarge Posted November 16, 2015 Author Share Posted November 16, 2015 Thanks Noel. I appreciate it, I think I had at least 15 hours into that dash. Probably 20. Hope you've been well, long time to see! Link to comment Share on other sites More sharing options...
lvsarge Posted December 7, 2015 Author Share Posted December 7, 2015 So the clutch problem is fixed, it's registered, and I have successfully taken this thing out for about a 3 mile drive. She runs great! I had to lean out the carb a little, and it can be a bit stubborn in the cold mornings but the truck drives, rolls, stops, and runs overall fantastic. I've still got bodywork to do, and paint eventually but I feel like I've resurrected this guy to close to it's former glory. Another brat on the road! More pics to come as I take them. Thanks for all of your help and support USMB. You guys have been a great wealth of knowledge on this journey so far. I really do, sincerely, appreciate all of it. 1 Link to comment Share on other sites More sharing options...
superpoo93 Posted December 8, 2015 Share Posted December 8, 2015 Congrats!! job well done, sir! Link to comment Share on other sites More sharing options...
lvsarge Posted December 11, 2015 Author Share Posted December 11, 2015 Little status update. Took her to work twice this week and she did fine on the road. Surprisingly quiet on the highway (all the dynamat helps), and no random rattles and shakes I used to get going 65 mph. Startups, especially cold, remain a problem. It appears to be affiliated with the choke. It seems my throttle plate doesn't close after the engine cools off and I blip the throttle. I had been playing with the choke trying to make it not too tight and not too lose, it just seems gummed up, so I will clean all the linkages and see if I can dial it in better. Link to comment Share on other sites More sharing options...
lvsarge Posted December 11, 2015 Author Share Posted December 11, 2015 One question though that I haven't quite figured out. When I make a very sharp left or right hand turn (obviously at low speeds) I get what sounds like metal tapping metal, I assume from the stabilizer bar. Anyone know why this may be occuring? It's definitely not a wheel bearing clunk (god I'd hope not since I changed them out), but more of a tap tap tap on metal, until I straighten the wheel. Link to comment Share on other sites More sharing options...
superpoo93 Posted December 12, 2015 Share Posted December 12, 2015 Could it be your axle nut not be tight? I had one start to back out and it made a sound like a cv joint... Link to comment Share on other sites More sharing options...
Wiclipse95 Posted July 12, 2016 Share Posted July 12, 2016 Wow, unbelievable thread, great work! The dash looks amazing. Where did you get the black carpet templet? Keep up the good work Link to comment Share on other sites More sharing options...
lvsarge Posted July 14, 2016 Author Share Posted July 14, 2016 On 7/12/2016 at 7:44 AM, Wiclipse95 said: Wow, unbelievable thread, great work! The dash looks amazing. Where did you get the black carpet templet? Keep up the good work Hey thanks Wiclipse. I can't remember where I got the black carpet. It was one of the major auto part companies online like Andy's, or Auto Geek. I don't recommend it though, it was cut pretty poorly, and didn't cover everything. Doing it again I'd have rather taken it somewhere to get a custom insert put in. As for the Brat in this thread, however, I have since traded it away and no longer own it, as of about 3 weeks ago. The new owner says he plans to take it to Michigan, so hopefully it won't rot to death out there, but who knows. I will start another thread on my yellow one if/when I get some time to dig in on it. It's just been sitting in my garage for a year and haven't had any time really to start in on it, yet. Link to comment Share on other sites More sharing options...
