2001 Legacy fuel sensor replacement
Look in the trunk right behind the rear seats under the carpet. Theres a plate on either side that comes up to get to the sensors for each half of the tank.
Check the wiring and the connector on top of the tank first. Mice like to get up there and chew on stuff. The terminals in the connector can also corrode and cause poor connection.
