the sucker king Posted June 18, 2014 Share Posted June 18, 2014 anybody know the horsepower of EJ18 EJ22 and EJ25? or any others for that matter. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 18, 2014 Share Posted June 18, 2014 Cars101.com Look in the archives section Link to comment Share on other sites More sharing options...
idosubaru Posted June 18, 2014 Share Posted June 18, 2014 wikipedia, rough approximations, usually close/right for HP numbers. cars101 engines aren't static - they change over time with production modifications. EJ22 went to OBDII in 1995, from dual to single port exhaust in 1996, to interference in 1997...from HLA's to screw type adjustments one year..every year in that time frame saw a change. very roughly off the top of my head:EJ18: 120hp EJ22: 130 - 142 depending on EJ25: 165 - 173 (or more) depending on year. Link to comment Share on other sites More sharing options...
ShawnW Posted June 18, 2014 Share Posted June 18, 2014 Check out the torque numbers too. The 1.8 is pretty nominal. Thinking of doing a swap? Link to comment Share on other sites More sharing options...
the sucker king Posted June 18, 2014 Author Share Posted June 18, 2014 On 6/18/2014 at 5:49 AM, ShawnW said: Check out the torque numbers too. The 1.8 is pretty nominal. Thinking of doing a swap? thinking of it yes. so many low mileage EJ22s in the local junkyards. I've seen a couple low mileage EJ18s recently as well. Link to comment Share on other sites More sharing options...
Uberoo Posted June 20, 2014 Share Posted June 20, 2014 EJ18 108 hp/110 lb ft - 118 hp/121 lb ft EJ22 135 hp/137 lb ft -142 hp/149 lb ft EJ25 155 hp/140 lb ft - 165 hp/162 lb ft After bore got to a certain point torque was less than HP. 1 Link to comment Share on other sites More sharing options...
